11-09-2011 06:19 AM - edited 03-07-2019 03:17 AM
I've been trying to upgrade out 7k to 5.1.3 via ISSU and keep running into failures. Does anyone know where I can look up the error code listed below?
Notifying services about system upgrade.
[# ] 0% -- FAIL. Return code 0x40B30029 (Operation failed. Fabric is already locked).
Pre-Upgrade check failed. Return code 0x40B30029 (Operation failed. Fabric is already locked).
n7k-1# install all kickstart bootflash:n7000-s1-kickstart.5.1.3.bin system bootflash:n7000-s1-dk9.5.1.3.bin
Verifying image bootflash:/n7000-s1-kickstart.5.1.3.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s1-dk9.5.1.3.bin for boot variable "system".
Verifying image type.
Extracting "lc-f1-n7k" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Extracting "bios" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Extracting "lc-m1-n7k" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Extracting "system" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Extracting "kickstart" version from image bootflash:/n7000-s1-kickstart.5.1.3.bin.
Extracting "cmp" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Extracting "cmp-bios" version from image bootflash:/n7000-s1-dk9.5.1.3.bin.
Performing module support checks.
n7k-1# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 3.22.0
kickstart: version 5.1(2)
system: version 5.1(2)
BIOS compile time: 02/20/10
kickstart image file is: bootflash:///n7000-s1-kickstart.5.1.2.bin
kickstart compile time: 12/25/2020 12:00:00 [12/18/2010 03:55:20]
system image file is: bootflash:///n7000-s1-dk9.5.1.2.bin
system compile time: 11/29/2010 12:00:00 [12/18/2010 05:02:00]
Hardware
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
Intel(R) Xeon(R) CPU with 8260944 kB of memory.
Processor Board ID JAF1507CCSH
Device name: n7k-1
bootflash: 2029608 kB
slot0: 0 kB (expansion flash)
Kernel uptime is 25 day(s), 22 hour(s), 39 minute(s), 17 second(s)
Last reset
Reason: Unknown
System version: 5.1(2)
Service:
plugin
Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
CMP BIOS version: 02.01.05
CMP Image version: 5.1(1) [build 5.0(0.66)]
CMP BIOS compile time: 8/ 4/2008 19:39:40
CMP Image compile time: 11/29/2010 12:00:00
CMP (Module 6) ok
CMP Software
n7k-1# dir flash:
No such file or directory
n7k-1# dir
279 Mar 04 11:53:36 2011 JAF1443BPAJ_155080054.lic
146170914 Mar 04 11:52:23 2011 n7000-s1-dk9.5.1.2.bin
146701191 Nov 08 13:54:42 2011 n7000-s1-dk9.5.1.3.bin
146258490 Nov 05 23:40:49 2011 n7000-s1-dk9.5.1.5.bin
30687232 Mar 04 11:51:32 2011 n7000-s1-kickstart.5.1.2.bin
30674944 Nov 08 13:56:01 2011 n7000-s1-kickstart.5.1.3.bin
30515200 Nov 05 23:38:27 2011 n7000-s1-kickstart.5.1.5.bin
4096 Nov 02 11:31:34 2011 vdc_2/
4096 Mar 04 12:37:32 2011 vdc_3/
4096 Mar 04 12:37:32 2011 vdc_4/
13284 Nov 02 13:11:12 2011 vlan.dat
Usage for bootflash://
658649088 bytes used
1180209152 bytes free
1838858240 bytes total
11-11-2011 10:49 AM
Can you issue the following command to see what or who has a lock.
show cfs lock
Once you know what has the lock you should be able to clear it.
01-28-2015 05:31 AM
How do we clear the lock once we know who has the lock?
01-28-2015 05:49 AM
"clear ntp session" cleared the lock.
