01-18-2018 09:47 AM - edited 03-08-2019 01:28 PM
Hi guys,
When I try to configure fex from Port eth1/1 to 1/48 it works perfectly, but when I try to do same thing from port eth1/49 to eth1/54 the command fex associate 101 doesn't work!
It says: ERROR: Invalid port mode - not switchport
interface eth1/51
switchport mode fex-fabric
fex associate 101
Even if I configure channel group command on the interface It doesn't work.
Any idea ?
Thank you,
Everton
Solved! Go to Solution.
01-18-2018 07:16 PM
I don't think you can use the 6 uplink ports as FEX ports.
From the 9k document:
The uplink module should not be removed from a Cisco Nexus 9300 Series switch that is running Cisco NX-OS Release 7.0(3)I1(1). The ports on the uplink module should not be used to connect FEX modules.
Link:
01-18-2018 10:42 AM
Are you using a breakout cable or straight 40Gig?
https://quickview.cloudapps.cisco.com/quickview/bug/CSCuz67752
01-18-2018 11:09 AM
Hi, I'm using a QSFP-H40G-AOC5m cable.
01-18-2018 11:20 AM
You are missing the switchport command on the interface.
For example
interface port-channel119
switchport
fex associate 119
01-18-2018 06:43 PM
Hi Ben,
The port is already in switchport .
This is the config below.
interface port-channel101
switchport
fex associate 101
I get this error message only if I try to configure any ports from 1/49 to 1/54.
If I configure ports from 1/1 to 1/48 it works perfectly fine.
Thank you
01-18-2018 07:16 PM
Link:
01-26-2018 12:28 PM
@Reza Sharifi You're right!
FEX Support for 93180YC-EX was added starting 70(3)I5(1) and later codes.
I upgraded the NXOS to 7.0.3.I7.2 version and the "fex associate" command is working now.
Thank you
01-26-2018 01:31 PM
Thanks for the update!
01-31-2018 12:22 PM
this is from release notes for 7.0(3)I1(1)
FEX
So, always check whether your model of Nexus and NX-OS does support the FEXes.
I donwgraded many times Nexus switches because of that.
In release notes it may look like NX-OS does support FEX extensibility, but for specific models of Nexus such feature was cut.
Cheers!
12-05-2018 06:51 PM
I trying this command and not having any luck... can you tell me what mode 9k it was that you did this on?
I have a C9372PX.
-Anthony Sarka
12-06-2018 06:54 PM
The Model is 93180YC-EX
Best of luck!
