Community Member
Nexus fabric extender and pinned links
Hello, I recently went through the DCNIS-2 training course and got a ticket from a client stating that he had some trouble with a 2148T which failed and restarted. If I run the commands "show system reset reason" and "show diagnostic result fex xxx" I get that there was no real reason for restarting and that physically all ports are OK nonetheless when I issue the command "show fex detail xxx" I can't seem to locate ports in the range of 42 to 48.
Ok, when I said "I issue and I run the commands" I was trying to refer to our client which hasn't given me access to conifguration.
So the final question is... the ports that are not showing in the "show fex detail" could be part of some vPC? is there any explanation to this because port pinning is set to 1.
N5K# show system reset-reason fex 102
----- reset reason for FEX 102 ---
1) At 0 usecs after Unknown time
    Reset Reason: Unknown (0)
    Service (Additional Info):
    Image Version: 4.1(3)N1(1a)
2) At 0 usecs after Unknown time
3) At 263769 usecs after Wed May  5 18:23:22 2010
    Reset Reason: Kernel Reboot (1)
    Service (Additional Info): Reload new image
4) At 0 usecs after Unknown time
    Image Version: 4.0(1a)N2(1)
N5K# Show fex 102 detail
FEX: 102 Description: FEX0102   state: Online
  FEX version: 4.1(3)N1(1a) [Switch version: 4.1(3)N1(1a)]
  FEX Interim version: 4.1(3)N1(1a)
  Switch Interim version: 4.1(3)N1(1a)
  Extender Model: N2K-C2148T-1GE,  Extender Serial: JAFxxxxxx
  Part No: 73-12009-05
  Card Id: 70, Mac Addr: 00:0d:ec:ce:6f:02, Num Macs: 64
  Module Sw Gen: 12338  [Switch Sw Gen: 20]
pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/9
  Fabric interface state:
    Po102 - Interface Up. State: Active
    Eth1/9 - Interface Up. State: Active
    Eth1/10 - Interface Up. State: Active
  Fex Port        State  Fabric Port  Primary Fabric
       Eth102/1/1  Down       Po102       Po102
       Eth102/1/2    Up       Po102       Po102
       Eth102/1/3    Up       Po102       Po102
       Eth102/1/4    Up       Po102       Po102
       Eth102/1/5    Up       Po102       Po102
       Eth102/1/6  Down       Po102       Po102
       Eth102/1/7    Up       Po102       Po102
       Eth102/1/8    Up       Po102       Po102
       Eth102/1/9    Up       Po102       Po102
      Eth102/1/10    Up       Po102       Po102
      Eth102/1/11  Down       Po102       Po102
      Eth102/1/12  Down       Po102       Po102
      Eth102/1/13  Down       Po102       Po102
      Eth102/1/14  Down       Po102       Po102
      Eth102/1/15  Down       Po102       Po102
      Eth102/1/16  Down       Po102       Po102
      Eth102/1/17  Down       Po102       Po102
      Eth102/1/18  Down       Po102       Po102
      Eth102/1/19  Down       Po102       Po102
      Eth102/1/20  Down       Po102       Po102
      Eth102/1/21    Up       Po102       Po102
      Eth102/1/22  Down       Po102       Po102
      Eth102/1/23  Down       Po102       Po102
      Eth102/1/24    Up       Po102       Po102
      Eth102/1/25  Down       Po102       Po102
      Eth102/1/26  Down       Po102       Po102
      Eth102/1/27  Down       Po102       Po102
      Eth102/1/28  Down       Po102       Po102
      Eth102/1/29  Down       Po102       Po102
      Eth102/1/30  Down       Po102       Po102
      Eth102/1/31  Down       Po102       Po102
      Eth102/1/32  Down       Po102       Po102
      Eth102/1/33  Down       Po102       Po102
      Eth102/1/34  Down       Po102       Po102
      Eth102/1/35  Down       Po102       Po102
      Eth102/1/36  Down       Po102       Po102
      Eth102/1/37  Down       Po102       Po102
      Eth102/1/38  Down       Po102       Po102
      Eth102/1/39  Down       Po102       Po102
      Eth102/1/40  Down       Po102       Po102
      Eth102/1/41  Down       Po102       Po102
Logs:
[10/27/2011 15:23:52.351003] Module register received
[10/27/2011 15:23:52.354119] Registration response sent
[10/27/2011 15:23:52.408755] Module Online Sequence
[10/27/2011 15:23:53.683804] Module Online
[10/27/2011 15:27:25.738784] Module disconnected
[10/27/2011 15:27:25.739876] Offlining Module
[10/27/2011 15:27:25.740381] Module Offline Sequence
[10/27/2011 15:27:28.75862] Module Offline
[10/27/2011 15:29:26.556690] Module register received
[10/27/2011 15:29:26.560015] Registration response sent
[10/27/2011 15:29:26.616726] Module Online Sequence
[10/27/2011 15:29:28.51180] Module Online
Everyone's tags (4)
505
