12-22-2011 11:54 PM - edited 03-07-2019 04:02 AM
Struggle to find the SNMP MIBS of the Nexus 5000 FEX tranceivers
Example below:
The following show commands display the serial numbers and part numbers of the FEX transceivers
switch# show interface transceiver fex-fabric
Ethernet1/5
sfp is present
name is CISCO-MOLEX INC
part number is 74752-9025
revision is A
serial number is MOC12302468
nominal bitrate is 12000 MBits/sec
Link length supported for 50/125mm fiber is 0 m(s)
Link length supported for 62.5/125mm fiber is 0 m(s)
cisco id is --
cisco extended id number is 4
Ethernet1/6
sfp is present
revision is A
serial number is MOC12260214
cisco id is --
Ethernet1/7
sfp is present
revision is A
serial number is MOC12301888
cisco id is --
Any idea which SNMP MIB to look for?
12-23-2011 02:07 PM
have you tried entity-mib already?
Riccardo
12-27-2011 11:33 PM
I've looked at it, but it seems that it only provide the following information
MIB | Description |
CISCO-ENTITY-EXT-MIB | Extends the entityPhysicalTable for modules with processors. For each of these modules, this MIB provides memory statistics and LED information. |
CISCO-ENTITY-FRU-CONTROL-MIB | Manages field-replaceable units, such as power supplies, fans, and modules. |
CISCO-ENTITY-SENSOR-MIB | Provides sensor data for environmental monitors such as temperature gauges. |
CISCO-IMAGE-UPGRADE-MIB | Provides module image management based on entPhysicalIndex. |
Key information required:
Ethernet1/5
sfp is present
revision is A
Will the entity MIB's mentioned before provide the neccesary information?
01-22-2013 08:12 AM
Hi Philip,
I am in the same situation as well. did you manage find a resolution for this ?
