Webcast-Catalyst9k
Nexus IOS load balancing.
Does Nexus IOS still support IOS server Load Balancing? If it does, where can I get the documentaion for it? Thank you in advance.
Re: Nexus IOS load balancing.
I don't believe it does. one would need to add either a 6500 services switch with an ACE blade if high throughput, or an ACE appliance if the throughput is less demanding.
We have the 6500 but still running on CATOS. We are only load balancing most likely our intranet, exchange and Citrix metaframe. We are in the works on getting NEXUS.
348
