Nexus N2K-2348TQ environment data
bmlakar
Nexus N2K-2348TQ (2 units of these type) is connected to N9K-C9396PX (running code 7.0(3)I2(4))
When environment data is checked, on one unit we could see there is no data for both power supplies.
Actually we could see similar on situation also on independent DR site. Anyway, fex is working normally, both PS ok.
Just for compare I listed fex115, which is ok, and faulty printout for fex117.
Anyone observed similar?
Kind regards,
Branko
show environment fex all
Temperature Fex 115:
Module Sensor MajorThresh MinorThres CurTemp Status
(Celsius) (Celsius) (Celsius)
1 Outlet-1 70 65 44 ok
1 Inlet-1 55 48 41 ok
1 Die-1 115 105 61 ok
Fan Fex : 115:
Fan Model Hw Status
Chassis N2K-2348TQ-FAN -- ok
PS-1 N2200-PAC-400W -- ok
PS-2 N2200-PAC-400W -- ok
Power Supply Fex 115:
Voltage: 12 Volts
PS Model Power Power Status
(Watts) (Amp)
1 N2200-PAC-400W 396.00 33.00 ok
2 N2200-PAC-400W 396.00 33.00 ok
Mod Model Power Power Power Power Status
Requested Requested Allocated Allocated
(Watts) (Amp) (Watts) (Amp)
1 N2K-C2348TQ-10GE 160.80 13.40 160.80 13.40 powered-up
Power Usage Summary:
Power Supply redundancy mode: redundant
Total Power Capacity 792.00 W
Power reserved for Supervisor(s) 160.80 W
Power currently used by Modules 0.00 W
Total Power Available 631.20 W
Temperature Fex 117:
1 Outlet-1 70 65 43 ok
1 Inlet-1 55 48 40 ok
1 Die-1 115 105 57 ok
Fan Fex : 117:
Fan Model Hw Status
Power Supply Fex 117:
Voltage: 12 Volts
(Watts) (Amp)
1 ------------ -- -- --
2 ------------ -- -- --
1 N2K-C2348TQ-10GE 0.00 0.00 0.00 0.00 powered-up
Total Power Capacity 0.00 W
Power reserved for Supervisor(s) 0.00 W
Total Power Available 0.00 W
show sprom fex all | include DISPLAY|Part|Product|H/W|Serial
DISPLAY FEX 115 SUP sprom contents
Product Number : N2K-C2348TQ-10GE
Serial Number : FOC21506SR2
Part Number : 73-16842-04
Part Revision : F0
H/W Version : 1.2
DISPLAY FEX 115 backplane sprom contents:
Serial Number : FOC2151R1PN
Part Number : 68-5579-01
Part Revision : J0
H/W Version : 1.2
DISPLAY FEX 115 power-supply 1 sprom contents:
Product Number : N2200-PAC-400W
Serial Number : DCA2139528W
Part Number : 341-0375-08
Part Revision : A1
H/W Version : 5.0
DISPLAY FEX 115 power-supply 2 sprom contents:
Serial Number : DCA2139528N
Part Revision : A1
H/W Version : 5.0
DISPLAY FEX 117 SUP sprom contents
Serial Number : FOC21506SYV
Part Revision : F0
H/W Version : 1.2
DISPLAY FEX 117 backplane sprom contents:
Serial Number : FOC2151R1PY
Part Revision : J0
H/W Version : 1.2
Reza Sharifi
Seems to be a cosmetic bug since the unit is working fine.
You may want to open a case for it.  Cisco most likely recommends an upgrade.
Hi Reza;
Yes, it is probably cosmetic bug since units are working normally.
Thanks for replay.
Best regards,
Branko
Correct. But I would still open a ticket to make sure Cisco knows about it and see if it is a known bug or not.
