Community Member
Nexus - Pseudowire
I try to put the command "xconnect" on my Nexus 7000 but it shows
>> NEXUS7009-LAB(config-if)# xco?
>>                                          ^ % Invalid command at '^'
Which feature set must be installed to provide the feature ?
Tks.
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Nexus - Pseudowire
Try this:
switch#
configure terminal
switch(config)#
interface ethernet 4/0/0.1
switch(config-if)#
encapsulation dot1q 100
switch(config-if)#
l2vpn xconnect context Test1
switch(config-xconnect)#
internetworking ethernet
VIP Super Bronze
Nexus - Pseudowire
  Also, make sure to install the feature set and enable mpls first:
install feature-set mpls
than
feature mpls
I think, you have to be admin VDC to install it
VIP Super Bronze
Nexus - Pseudowire
Try this:
switch#
configure terminal
switch(config)#
switch(config-if)#
switch(config-if)#
VIP Super Bronze
Nexus - Pseudowire
than
feature mpls
295
