Nexus switch
vinit.ccna
I have inserted a 1000Base SFP in Nexus 5000 and SFP is also validated but still it's showing link not connected. Port status is as below
DELHALNPSW5548-01# sh int Eth1/20
Ethernet1/20 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 547f.eeab.1bdb (bia 547f.eeab.1bdb)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  auto-duplex, 1000 Mb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 00:21:10
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
Richard Burts
Could you post the configuration of the interface?
Can you tell us what is connected to the SFP? And can you verify that whatever is connected has activated its interface?
Rick
Rick
I had this issue also when we first started configuring our N5ks a few months ago.  Even though the N5k recognized the SFP we had to configure the interface with "speed 1000" before the link would come up.
Hope this helps!
vinit.ccna
Issue is resolved after changing the interface speed.
