Nexus Upgrade
I am planning a Nexus 5k upgrade (5548) and plan to move from our current NX_OS n5000-uk9.5.0.3.N2.1to
5.2.1.N1.3.
There is an alternate option of 5.1(3)N2(1c).
Is there any reason why I should choose one of these options over another. I have examined all the documantation I can find and can see no reason not to move to the 5.2.1x release, is this a sensible course from 5.0.3.N2.1.
Are there any issues with the 5.2 release train when compared to upgrading to the 5.1 release.
Any advice and guidance would be very much appreciated.
Many Thanks
Steve
  • LAN Switching and Routing
Everyone's tags (2)
4 ACCEPTED SOLUTIONS
Silver
Nexus Upgrade
I am not sure about the issues with 5.2 but don't upgarde to 5.1. We are currently on 5.1.3.N2.1a and ran into a bug (CSCtt10736) recently and had to reboot both the switches (5548 with L3) to fix the issue. Working on upgrading our switches to 5.2 also..
Siddhartha
Siddhartha
Nexus Upgrade
Steve,
Its worth to go ahead and refer the release notes for the 5.2 release.
YEs certainly its good than 5.1.X version.
Inayath
Hall of Fame Super Silver
Nexus Upgrade
Cisco is currently recommending 5.2(1)N1(4). Reference.
I have installed this at several customers' sites and it's working well.
Nexus Upgrade
Thanks for the update. I hope your query is solved now , could you plz mark the thread as answered rather than leaving as unanswered.
Inayath
Silver
Nexus Upgrade
Siddhartha
Siddhartha
Nexus Upgrade
Steve,
Inayath
Nexus Upgrade
Nexus Upgrade
Thanks all,
Looks like it is 5.2.x for us then. Thanks for all the info.
Cheers
Steve
Nexus Upgrade
Inayath
395
