06-05-2012 02:01 AM - edited 03-07-2019 07:04 AM
There are two IBM servers that will be connected to Nexus 2k switch.
Two Ethernets from each server will be terminated on the Nexus2k.I
In all 4 ports will be part of a single ether channel which will communicating through LACP
Please let me if this is possible and what will be the configuration steps.
06-07-2012 03:20 PM
The Nexus 2K is 2148T. Can anyone help me on this?
06-07-2012 03:25 PM
It should work just fine. Remember the 2k does not work by itself, you also need to have a set of 5Ks or 7Ks to uplink the 2ks to.
06-11-2012 07:59 AM
Hello Jaffrey
You also need to configure both your servers to send same LAG ID for LACP link - to let N2k box now that all these links are part of the same port-channel.
HTH,
Alex
