I have here two Nexus7k chassis and I want to make use of the CFS feature. As far as I understood, it is using multicast for synchronising the configuration on both chassis.
Both SUP management interfaces are connected to an old 3550 rackswitch and provide out-of-band management.
Q1: Do I now additionally need to configure PIM or IGMP on the rackswitch in order to get CFS working properly?
Q2: Shouldn't I see both peers on the output below if everything is working right?
SwitchB# sh cfs peers name ntp
Scope : Physical-fc-ip
Switch WWN IP Address
20:00:00:26:98:09:7f:41 <ip omitted> [Local]
Total number of entries = 1
SwitchB# sh cfs status
Distribution : Enabled
Distribution over IP : Disabled
IPv4 multicast address : 239.255.70.83
IPv6 multicast address : ff15::efff:4653
Distribution over Ethernet : Enabled
SwitchB#
SwitchB# sh run | sec ntp
ip access-list copp-system-acl-ntp
10 permit udp any any eq ntp
20 permit udp any eq ntp any
ipv6 access-list copp-system-acl-ntp6
match access-group name copp-system-acl-ntp
match access-group name copp-system-acl-ntp6
ntp distribute
ntp server <ip omitted> use-vrf management
ntp commit
SwitchB#
Your help is very welcome!
cheers
phil
