Nexus7K to Nexus5K L3 port-channel
Hi, im trying to have an l3 port-channel(with 2 physical ports on both ends; without vpc) between a Nexus 7k and 5k, though the port-channel comes up, it comes up with only one link up. The other link shows
"Ethernet3/5 is down (suspended(no LACP PDUs))
  Dedicated Interface
  Belongs to Po11"
on N7K end and
Group Port-       Type     Protocol  Member Ports
      Channel
11    Po11(RU)    Eth      LACP     Eth1/5(I)    Eth1/6(P)
on the other end.
The configs from both ends are as below;
N7K1-CORE1# sh run int eth3/5
!Command: show running-config interface Ethernet3/5
!Time: Tue Mar 13 21:43:07 2012
version 6.0(1)
  description *** L3_PO11_Link_to_N5K-AGG-1_Eth1/5 ***
  channel-group 11 mode active
  no shutdown
N7K1-CORE1# sh run int eth3/6
!Command: show running-config interface Ethernet3/6
!Time: Tue Mar 13 21:43:09 2012
version 6.0(1)
  description *** L3_PO11_Link_to_N5K-AGG-1_Eth1/6 ***
  no shutdown
N7K1-CORE1# sh run int po11
!Command: show running-config interface port-channel11
!Time: Tue Mar 13 21:43:21 2012
version 6.0(1)
  description *** L3_PO11_Link_to_N5K-AGG-1 ***
  ip address 10.0.1.29/30
  ip router ospf 10 area 0.0.0.0
N7K1-CORE1#
AGG-N5K-1# sh run int eth1/5
!Command: show running-config interface Ethernet1/5
!Time: Tue Mar 13 18:39:42 2012
version 5.0(3)N1(1c)
  description *** L3_PO11_Link_to_N7K-CORE-1_Eth3/5 ***
  no switchport
AGG-N5K-1# sh run int eth1/6
!Command: show running-config interface Ethernet1/6
!Time: Tue Mar 13 18:39:44 2012
  no switchport
AGG-N5K-1# sh run int po11
!Time: Tue Mar 13 18:39:48 2012
  description *** L3_PO11_Link_to_N7K-CORE-1 ***
  no switchport
  speed 10000
  ip address 10.0.1.30/30
AGG-N5K-1#
can you please help me to find a reason for this.
Everyone's tags (2)
490
