NHRP strange ! Stuck !
illusion_rox
Hi guys, i searched cisco site, but could find any bug or troubleshooting regarding below mentioned issue.
I am using DMVPN, and its running successfully for like 20-30 spokes. On hub when i issued debug nhrp for some checking i got these with TONS, believe me 100 of msgs showing below
1w0d: NHRP: NHRP successfully resolved 172.27.64.20 to NBMA 192.168.202.26
Now, 172.27.64.20 is tunnel ip of one of my spoke. call it spoke20. as soon as i shut the nhrp tunnel from spoke20 these msgs stop. Strange thing is that, when i do debug at spoke20 (debup nhrp) it shows me normal behaviour, whereas on hub i am still getting them continuously as soon as i bring up the tunnel. Can some1 guide me what might be the issue ? config are below
Hub
ip address 172.x.x.x 255.255.192.0
no ip redirects
ip flow ingress
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 10
no ip nhrp cache non-authoritative
ip ospf network point-to-multipoint
ip ospf hello-interval 10
ip ospf mtu-ignore
tunnel source a.b.c.d
tunnel mode gre multipoint
tunnel key 1000
tunnel protection ipsec profile test
Spoke20
ip address 172.27.64.20 255.255.192.0
ip nhrp map 172.27.64.1 192.168.205.18
ip nhrp map multicast 192.168.205.18
ip nhrp nhs 172.27.64.1
ip nhrp registration timeout 500
ip ospf network point-to-point
ip ospf mtu-ignore
tunnel source 192.168.202.26
tunnel destination 192.168.205.18
tunnel key 1000
I am really confused as to why this happening, i have seen that after shutting this spoke20, i get same types of msgs for some other spoke !!! but they are not in that volume as compared to this particular spoke. Meanwhile i am changing the ios on spoke20, if you have any good ideas pls share with me. this is very critical
Thanks in advance
Giuseppe Larosa
Hello Ovais,
I may be wrong but I don't see any trouble on the message itself the number of messages can be a trouble for you during troubleshooting.
this just means NHRP is working well
I wonder if you should enable nhrp cache on hub
caching the information should reduce NHRP activity and so the number of these messages.
Hope to help
Giuseppe
Dear Giuseppe, thanks alot for feedback, but i have already tried this but no use. There is 1 more thing i observed on spoke20. Ospf hellos are send like TONS within msecs !!!! see below
Jan 15 11:08:41.134: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.170: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.206: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.242: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.278: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.314: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.350: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.386: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.422: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.458: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.494: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.530: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.566: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.602: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
*Jan 15 11:08:41.638: IP: s=172.27.64.20 (local), d=224.0.0.5 (Tunnel222), len 80, sending broad/multicast
they are same like TONs of them. i did show ip ospf int tun 222
Last flood scan length is 1, maximum is 4
Last flood scan time is 0 msec, maximum is 13900 msec
Flood pacing timer due in 24 msec
flood pacing timer really caught my eye. I checked on other spokes but i only see this on this spoke20. Can some1 tell me how to disable this flood pacing, i tried interface level ip ospf flood reduction, but no use :(
kindly help me out
