Webcast-Catalyst9k
NIC teaming (NFT) failover time
How much time does it take a server attach to two swith using hp NFT to detect a link failure on the primary link.
Let's say the link failure is cause by power been removed from the first swith
1 REPLY
Silver
Re: NIC teaming (NFT) failover time
I think if you disable NIC teaming then SQL and Unity start correctly. Checked NIC teaming configuration and they are identically configured except the version is different.
787
