11-22-2011 07:45 AM - edited 03-07-2019 03:32 AM
Hello Everyone:
As shown in the attached diagram. When I ping the Virtual IP on the server I lose a ping over every 6 in the first 2 configurations.
When I replace the Nexus 5K by a Catalyst 3560, the result is smooth.
As you can see in the second topology I am connecting both 4K to the same N5K in order to get the VPC peer link in the equation but still no success.
Any ideas appreciated.
Note: 4K does not support VPC natively.
Something I observed in the first two topologies is that the MAC address for the server as seen on the NEXUS flaps constantly at a rate on 1 evry 7 sec(aprox.)
For example in topology 2:
When I do a show MAC I will see MACX being learned from port 16 and it will bounce to port 15 for about 1 sec ang go back to port 16.
Thanks for any input.
11-22-2011 08:20 AM
Like you said, the N4K doesn't have vPC support and your first and second diagrams are not supported.
The question is do you want additional bandwidth with active-active? Or is there any other failure scenario that your server wouldn't failover correctly?
jerry
11-22-2011 08:48 AM
Thanks for your response:
LACP was not configured on the server(IBM BLADE).
NIC teaming was configured with one active NIC and one standy NIC and still the ping was timing out every 6 request as shown below in the second topolgy.
The primary goal is to have NIC teaming either in standy mode or load-sharing mode on the(outound) working.
I am suprised that it does not work on topology 2 as there is only one switch as parent.
Pinging 10.130.100.149 with 32 bytes of data:
Request timed out.
Reply from 10.130.100.149: bytes=32 time=43ms TTL=122
Reply from 10.130.100.149: bytes=32 time=21ms TTL=122
Reply from 10.130.100.149: bytes=32 time=22ms TTL=122
Reply from 10.130.100.149: bytes=32 time=27ms TTL=122
Request timed out.
Reply from 10.130.100.149: bytes=32 time=19ms TTL=122
Reply from 10.130.100.149: bytes=32 time=20ms TTL=122
Reply from 10.130.100.149: bytes=32 time=25ms TTL=122
Reply from 10.130.100.149: bytes=32 time=23ms TTL=122
Request timed out.
Reply from 10.130.100.149: bytes=32 time=34ms TTL=122
Reply from 10.130.100.149: bytes=32 time=130ms TTL=122
Request timed out.
Reply from 10.130.100.149: bytes=32 time=36ms TTL=122
Reply from 10.130.100.149: bytes=32 time=41ms TTL=122
Here is where the MAC is flapping:
NX5596-1.CTB# sh mac address-table | inc 0010.1870.7710
* 1312 0010.1870.7710 dynamic 0 F F Eth1/15
* 1312 0010.1870.7710 dynamic 0 F F Eth1/16
11-22-2011 09:59 AM
I am not a server guy so I can't really comment on NIC teaming (active-standby) configuration. From my previous experience with an customer running N4K, active-standby NIC teaming should be okay.
On the other hand, you should not configure load-balancing on the server side because it will cause MAC for sure.
jerry
11-22-2011 10:08 AM
Thanks Jeye:
That is what I though too. That is standby active should have no issue.
If I get the Standy-ACtive working I will be more that happy. We have now a Case open with Cisco and also on the server side.
11-22-2011 10:19 AM
Not a problem.
jerry
03-05-2014 01:32 AM
Hi Shummoogum,
I actually have the same issue. How did you resolve it?
Thank you very much for your help.
Oscar
