NIC Teaming vs 2 Network cards with 2 IP's (EtherChannel Limitation)
Hi All,
I would like to ask a question about NIC Teaming vs 2 Network cards with 2 IP's
We have several Cisco Catalyst 3750's stacked and I have just read that there is a limit of 12 EtherChannels total for the whole stack
Does that mean I can only have 12 HP Proliant servers configured with NIC Teaming?
If that is the case which servers would you configure with NIC Teaming and which would you give 2 IP's, for example would a DC be OK with 2 IP's? Would Exchange be OK? IIS?
Thanks for any opinions or answers
alex t
1 ACCEPTED SOLUTION
Re: NIC Teaming vs 2 Network cards with 2 IP's (EtherChannel Lim
You don't mention the switch model, if you are using Gb ports remember the stack has only 32Gb throughput, 40 x 2Gb etherchannels running at capacity would have trouble.
I have never setup that many etherchannels on one device, but if Cisco support it there shouldn't be any additional issues as long as you follow the guidelines.
** Please rate posts if helpfull **
From the software configuration guide you can have 48 Etherchqnnels on the same stack with version 12.2.25 software.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805a64f4.html#wp1275881
HP Teaming has multiple variations, what are you aiming for, bandwidth or resiliance? You only require an etherchannel for bandwidth, for resiliance only you can connect into different switches and it still works.
Hi Mark,
Thanks for the quick reply
The initial reason we were looking in to NIC Teaming was resiliance but were are now interested in both or a mix
Being able to have up to 48 EtherChannels helps, any idea if having 40 brings any performance issues to the switch?
320
