08-14-2009 11:04 PM - edited 03-06-2019 07:15 AM
hi,
Does this module support only Full duplex? because even if I enter "duplex half" nothing happens, and a "show interface..." still displays "full duplex"
Solved! Go to Solution.
08-15-2009 12:08 AM
it should be supported
http://www.cisco.com/web/ANZ/cpp/refguide/hview/router/3700.html
is the other side using indeed half duplex?
I suggest that you leave duplex to auto.
08-15-2009 12:08 AM
08-27-2009 08:58 AM
yes, one is half, the other end is full.
I put both sides in full duplex. That's a better.
