Webcast-Catalyst9k
NME-16ES-1G-P module on a 2811
I have a NME module which had phones plugged into it. I have an IP address 192.168.0.1 on fa0/0 of the router which is the default gateway for Data. I need to create a vlan for phones on the switch and then be able to plug PC;s into the phone. How do I accomplish so that Pcs plugged into the phones can get to 192.168.0.1 which will be its DG? What IP address will I assign to Vlan 1 on the switch?
Please rate useful posts.
1 REPLY
Re: NME-16ES-1G-P module on a 2811
Check out the below link for configuration of voice vlan hope this helps out your query !!
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_20_se/configuration/guide/swvoip.html
Ganesh.H
698
