NME-X-23ES-1G EtherSwitch Service Module Images
Recently we purchased some NME-X-23ES-1G EtherSwitch service modules.  The IOS on each module is c3750-ipbase-mz.122-35.SE5 / 12.2(35)SE5.  Since it is the base feature set, it does not support IPSLA, which we require.
After consulting the support site; I located the IOS images that are current for these modules; however, the file names specify “3560” and not “3750”, and none of them appear to be “services”, which would have IPSLA.
I also attempted to upgrade to c3750-advipservicesk9-mz.122-35.SE5 (using the web GUI), but it would not accept this.  I considered TFTP upload of the .bin file, but I don't want to take the risk until I know it's compatible with the module.
What is the correct IOS image for the NME-X-23ES-1G EtherSwitch service module that supports IP SLA?
Re: NME-X-23ES-1G EtherSwitch Service Module Images
Check out the ios 12.2(40)SE for  Cisco Catalyst® 3750-E, 3750, 3560-E, 3560, 2960, 3550, and 2970 Series Switches; and Cisco Catalyst Blade Switch 3000 Series.
and check out the below link for more information for ios 12.2(40)SE
http://www.ciscosystems.or.at/en/US/prod/collateral/iosswrel/ps8802/ps6969/ps5012/prod_bulletin0900aecd806b9e79.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
VIP Super Bronze
Hi Larry,
The correct IOS is any IOS for the 3750 series
Reza
999
