08-20-2009 12:42 PM - edited 03-06-2019 07:21 AM
I'm using Secure Crt for console access to all cisco devices. This morning i can no loger communicate with cisco 3750's through console port, i tried on 3 different 3750's with same result. That same secure crt set up worked fine with firewall and switches. Any clues of what is wrong? Thx.
08-20-2009 12:45 PM
Check the cable connection, try putty or hyperterminal.
Perhaps it may be also a problem on your pc, reboot that one as well.
On hyperterminal click on DEFAULT for the serial connection settings.
08-20-2009 12:49 PM
Make sure that you're actually at the default speed of 9600 baud. Try different speeds etc.
HTH,
John
08-20-2009 12:57 PM
If you have rebooted since using it on the firewalls and you are using a usb connector check to make sure the pc didn't use a different com port when it rebooted.
08-20-2009 03:19 PM
undocked the laptop Secure Crt re-acted funny :-), I tried using the Hyperterm and it works fine. Thanks everyone.
