No Conf Menu
Part Number : 73-9925-04
PCA Assembly Number : 800-26579-04
PCA Revision Number : A0
PCB Serial Number : FOC102548A0
Top Assembly Part Number : 800-26804-02
Top Assembly Serial Number : FTX1026B3K6
Top Revision Number : B0
Product/Model Number : AIR-LAP1242AG-A-K9
I currently have a Cisco Aironet 1242 that will boot and I can enter the default password of "Cisco". Once in the AP I am unable to open the CONF T menu.
When enter the AP says its an invalid command.
Any ideas?
  • LAN Switching and Routing
Hall of Fame Super Silver
Re: No Conf Menu
Hello Jason,
you may need to get privileged access first:
enable
if you don't know the enable password you need to use the appropriate password recovery procedure
Hope to help
Giuseppe
Purple
Re: No Conf Menu
Sounds like you are not in enable mode . Type enable then enter cisco again.
Hall of Fame Super Gold
Re: No Conf Menu
1. This should be in the Wireless forum.
2. The reason why you are getting the "Command disabled" when you enter ANY command on the AP is because you are running the CAPWAP/LWAP image.
There are two specific directions you can go and I need to know whether or not you want to let your AP operate in Autonomous Mode or CAPWAP/LWAPP mode (aka Wireless LAN Controller).
161
