08-06-2008 07:16 AM - edited 03-06-2019 12:39 AM
Hello ,
my problem is to connect a cisco 876 to a lan. When I connect to the fastethernet 0,1 ,2 , with a crossover to a pc i can connect to the router over telnet and ping it.
But when I connect the router on fastethernet 0 or 1,2,3 I can't connect to the router and on the router I'm only able to ping himself.
a debug ip packet shows:
telnet 192.168.251.1
Trying 192.168.251.1 ...
*Mar 1 10:38:10.282 CET: tcp0: O CLOSED 192.168.251.1:23 192.168.251.8:44032 seq 934063064
OPTS 4 SYN WIN 4128
*Mar 1 10:38:10.282 CET: IP: tableid=0, s=192.168.251.8 (local), d=192.168.251.1 (Vlan1), routed via RIB
*Mar 1 10:38:10.282 CET: IP: s=192.168.251.8 (local), d=192.168.251.1 (Vlan1),
len 44, sending
len 44, encapsulation failed
*Mar 1 10:38:12.282 CET: tcp0: R SYNSENT 192.168.251.1:23 192.168.251.8:44032 seq 934063064
OPTS 4 SYN WIN 4128
*Mar 1 10:38:12.282 CET: IP: tableid=0, s=192.168.251.8 (local), d=192.168.251.1 (Vlan1), routed via RIB
*Mar 1 10:38:12.282 CET: IP: s=192.168.251.8 (local), d=192.168.251.1 (Vlan1),
len 44, sending
please help
the configuration of the 876 is attached,
sh ver:
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(15)T6,
RELEASE SOFTWARE (fc2)
Cisco 876 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FCZ104820LY
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
08-06-2008 12:03 PM
Hello, how is the Switchport configured?
On which vlan is the Switch Management IP, VLAN1?
Maybe a show run interface xx where the router is connected to, helps us.
Will the switch route, who is 192.168.251.1 (seperate router) ?
Sebastian
08-06-2008 12:10 PM
Besides what was requested before, if the interface is down/down, make sure you are using the correct cable (straight)
08-06-2008 12:12 PM
Sebastian
