no ip redirects/no ip proxy-arp in GLBP
alsayed
hello!
when you configure GLBP ON THE interface vlan.do we need to configure no ip proxy-arp?it works without this command as well as this command also:no ip redirects
7 Replies 7
Jon Marshall
Hi Ali
They are not really related as such. You can run GLBP with them on or off. I usually turn off any unneeded services under the interface.
Jon
Edison Ortiz
proxy-arp provides services for devices on that segment that do not have a default gateway. If you want to ensure the devices on that segment use the GLBP VIP address, then disabling proxy-arp will be recommended.
As for ip redirect, it has no correlation to GLBP but is a recommended security practice to disable it. If you disable ip redirect, the devices on that segment will always contact their default gateway (GLBP VIP) if more than one gateway exists on that segment.
hello experts!
i have seen the following config under:
HSPR
INT VLAN X
NO IP REDIRECTS
GLBP
INT VLAN X
NO IP PROXY ARP
SO WHAT THAT MEAN?
MANY 10XS
HELLO
if i forget to configure it under the vlan interface(no proxy arp).then what's hapen?
10xs
If you forget to configure no ip proxy-arp under an interface, devices on that subnet with missing default gateway will be serviced by this interface.
For instance,
If you have a workstation with IP 192.168.1.150 (missing its default gateway) and a switch with 192.168.1.1 with proxy-arp enabled, the switch will respond to arp queries from the workstation and route to other segments on the workstation's behalf.
This behavior will cause a lot of overhead in the switch and network as you rely on ARP for routing to other segments.
By disabling proxy-arp, the switch does not route the packet and the workstation gets a request time-out if the destination resides in another subnet.
As said above these commands are generally configured as a security practice.
have a look at the attached document
Narayan
10xs narayan
