Webcast-Catalyst9k
No port status on C2960 after upgrade from 12.2(46) to 12.2(50)
After upgrading a test swicth C2960-48TC-L from 12.2(46)SE to 12.2(50)SE I do have no port status anymore in the CISCO Network Assistent. All port are marked blue.
Here are the slices of my running config:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
crypto pki trustpoint HTTPS_SS_CERT_KEYPAIR
enrollment selfsigned
serial-number
revocation-check none
rsakeypair HTTPS_SS_CERT_KEYPAIR
crypto pki certificate chain HTTPS_SS_CERT_KEYPAIR
certificate self-signed 01
ip default-gateway uuu.vvv.www.xxx
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxx
length 0
transport input ssh
line vty 5 15
transport input ssh
Re: No port status on C2960 after upgrade from 12.2(46) to 12.2(
Do you have any special or extra feature requirement which Old IoS was not suporting and you decided for IoS upgradation.
Simply, asking for better understanding.
Jimmy
The only reason for planning the upgrade is the security issues that are solved in 12.2(50)SE.
Roland
No, I was forced by some security issues which are solved in IOS 12.2(50).
Roland
Did you already find a solution for this phenomenon? We have the same problem on multiple switches 2960, 3750 but for some reason not on the 3560
Pity wise not. I do have this incident only on the 2960 and NOT on my 3750.
Mayby I spend some hours by playing around with the aaa-new-model & the ip http authentication config in my testlab.
Hall of Fame Super Gold
Try using the 12.2(50)SE1 instead of the SE.
That I did already. Same result as before.
And the Cisco Network Assistant is the latest version?
YES; It is CNA 5.4.
I'm having the same problem. All ports on the switches are blue except for our 3750s. I upgraded from 122(25)SEE3/4 to 122(50)SE. Did you end up finding a fix for this issue?
268
