No power in POE devices
titozep99
Our 3560G-24 switch suddenly lost POE ports (with IP phones connected to them) at the same time. In the log there is this error:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/x: Power given, but Power Controller does not report Power Good
I isolated the switch, disconnect everything and reconnect just one device for testing. I have tried some things recommended with no luck (shut down and up, change cable, IP Phone, etc, no power inline auto, etc.). Here some command outputs:
#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
#sh pow inl
Available:370.0(w) Used:0.0(w)  Remaining:370.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/1     auto   faulty     0.0     n/a                 n/a   15.4
Gi0/2     auto   off        0.0     n/a                 n/a   15.4
Gi0/3     auto   off        0.0     n/a                 n/a   15.4
Gi0/4     auto   off        0.0     n/a                 n/a   15.4
Gi0/5     auto   off        0.0     n/a                 n/a   15.4
Gi0/6     auto   off        0.0     n/a                 n/a   15.4
Gi0/7     auto   off        0.0     n/a                 n/a   15.4
Gi0/8     auto   off        0.0     n/a                 n/a   15.4
Gi0/9     auto   off        0.0     n/a                 n/a   15.4
Gi0/10    auto   off        0.0     n/a                 n/a   15.4
Gi0/11    auto   off        0.0     n/a                 n/a   15.4
Gi0/12    auto   off        0.0     n/a                 n/a   15.4
Gi0/13    auto   off        0.0     n/a                 n/a   15.4
Gi0/14    auto   off        0.0     n/a                 n/a   15.4
Gi0/15    auto   off        0.0     n/a                 n/a   15.4
Gi0/16    auto   off        0.0     n/a                 n/a   15.4
Gi0/17    auto   off        0.0     n/a                 n/a   15.4
Gi0/18    auto   off        0.0     n/a                 n/a   15.4
Gi0/19    auto   off        0.0     n/a                 n/a   15.4
Gi0/20    auto   off        0.0     n/a                 n/a   15.4
Gi0/21    auto   off        0.0     n/a                 n/a   15.4
Gi0/22    auto   off        0.0     n/a                 n/a   15.4
Gi0/23    auto   off        0.0     n/a                 n/a   15.4
Gi0/24    auto   off        0.0     n/a                 n/a   15.4
# test cable tdr int gi0/1
#sh cable-diagnostics tdr int gi0/1
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/1     auto  Pair A     152  +/- 4  meters N/A         Normal
                Pair B     149  +/- 4  meters N/A         Normal
                Pair C     1    +/- 4  meters N/A         Short
                Pair D     1    +/- 4  meters N/A        Short
I know Pair C controls PoE and pair D GigabitEthernet. If I connect a non-poe device all appears "Normal"
I think the internal PS is faulty. Is there any additional tests or command to fix or to confirm this?
Thank you for your help.
11 Replies 11
mahmoodmkl
Level 7
Level 7
I think u need to RMA this device
glen.grant
    That's pretty old code , upgrade the code and reload if that doesn't fix it , it is RMA time then
Leo Laohoo
Hold on, folks!
I've seen that error message like that, particularly on the 3560.
Can you first, DISABLE the port and reboot the switch.
After the bootup process, post the output to the command "sh post".
And then enable the port.
Here's the output:
#sh post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
I enabled the port. Error appeared again.
Post the "sh log".
If you remove the connection from the switch, do you still get a "faulty" output?
#sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 156 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 156 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Trap logging: level informational, 159 message lines logged
Log Buffer (4096 bytes):
er port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:42:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:42:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:42:36: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:42:51: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:43:06: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:43:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:43:37: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:43:53: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:44:08: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:44:24: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:44:41: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:44:56: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:45:11: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:45:26: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:45:42: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:45:57: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:46:14: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:46:29: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:46:44: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:47:00: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
00:47:15: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, In
00:49:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Pow
...continues
No, Leo. Anythig else seems to work well.
#sh power inl
                            (Watts)
Gi0/1     auto   off        0.0     n/a                 n/a   15.4
Gi0/4
Hmmmm ... Sounds like the guys are right.  You need to RMA the appliance.
A bit strange that the bootup process can't see parts of the PoE controller is failing.
I upgraded the code and now:
1) I have an additional message:
00:15:34: %ILPOWER-7-DETECT: Interface Gi0/1: Power Device detected: Cisco PD
00:15:51: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/1: Power given, but Power Controller does not report Power Good
2) sh power inline does not report a faulty connection:
SW_ALMACEN#sh power inli
Available:370.0(w)  Used:15.4(w)  Remaining:354.6(w)
                            (Watts)
Gi0/1     auto   on         15.4    Cisco PD            n/a   15.4
3) Cable diagnostics shows:
                Pair B     152  +/- 4  meters N/A         Normal
I will RMA the device
Thank you...
  If that cable test is correct that cable is wayyyyyyyyyyyy too long at almost 500 ft .  It probably wouldn't allocate power if the line is that long or the very least not work correctly..  Also you will never get a gig connection with 2 pairs showing a short as gig takes all 4 pairs .  If you have to run that far you will need media convertors and fiber between the devices.
The cable I am using is 3ft (0.9mt) long and all 4 pairs are in good condition.
That's one thing I hate about doing TDR on a 3560, 4K/6K.
I believe only the 2960-series and the 3750-series TDR is good.
Haven't tried doing TDR on a Nexus.
