no spanning-tree optimize bpdu transmission
jmistich
What is "spanning-tree optimize bpdu transmission". I have this in a bunch of my switches and haven't found a good reference for it. TIA.
-John
2 Accepted Solutions
Check Bug CSCee70806 at
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
____________________
Release Notes
"no spanning-tree optimize bpdu transmission" cannot be removed from the "show running" output.
No workaround available
_________________________
Fixed-in Version: 12.2(25)SE
The cool feature is that it optimizes bpdu transmission as the name states. However, when enabled it causes high CPU utilization since it runs in software, not hardware.
Cisco decided to disable this feature and hide it from the config. I guess some releases did not hide the command hence a bug was entered against it.
8 Replies 8
Edison Ortiz
Basically, this command shouldn't be seen in the config and the 'no' option should be removed. It's a bug in the IOS, what platform are you running ?
I have it on 3750s and 2955s. I am running 12.2(various).
Release Notes
I thought there might have been a cool feature I wasn't aware of. Oh well. Thanks.
Edison,
Can you elaborate more on this? In older versions of 3750 code "no spanning-tree optimize bpdu transmission" showed up in the config and could not be changed. With new versions 12.2(25)SEE3 and 12.2(35)SE5, if you do a "write erase" and reload, the command is missing from the config meaning it's entered and on by default. Now where I'm confused is if I do a "default spanning-tree optimize bpdu transmission", the command shows up as no spanning-tree optimize bpdu transmission, like the older code.
So moving forward should it be "spanning-tree optimize bpdu transmission" or "no spanning-tree optimize bpdu transmission"? From your previous post you indicated it could cause high CPU utilization, so it should be turned off with "no spanning-tree optimize bpdu transmission"? I'm I understanding this correctly?
Edison, - Need your help on this one...
You are correct and the command should be hidden in the config as its the default value is "no spanning-tree optimize bpdu transmission".
The fact the command can be seen, it's a cosmetic bug.
HTH,
__
Edison.
