no switchport
is it enough if one physical port is set to no switchport for making the intervlan communication to happen and should we need to enable ip routing command?
Re: no switchport
You'll still need to turn on ip routing.
Re: no switchport
Just to clarify u r trying to use a single port or multiple ports for intervaln routing by converting it/them to L3 port.if u r using a single port then i think it will not support sub-intefaces.
Mahmood
422
