01-03-2012 08:26 AM - edited 03-07-2019 04:09 AM
Our company is planning for D-Link Router and switched ,do they get configured in similar way like CISCO switches and routers does ?
01-03-2012 01:05 PM
CLI? No.
HTML? Yes.
What kind of D-Link router?
01-04-2012 12:38 AM
hi,
some of the d-link router and switches actually support a CLI.
but never worked with it, so i dont know if its like the cisco CLI, but i doubt it.
florian
01-04-2012 02:38 AM
D-Link
Cisco
01-04-2012 02:48 AM
D-Link routers are manufactured by a chinese OEM called BDCOM and its command line is simply a copy n paste from Cisco. You can configure them easily but real problem comes when these product fails. DLink will never provide you an advance replacement.
Had faced hardtimes with D-Link products so would recommed you buying few extra units for cold standby.
Pawan Sharma
01-04-2012 03:40 AM
First of all
This is a cisco forum, whatever answers you get will be colored by that.
D-Link have two different lines.
1 is consumer products small ie routers and firewalls switches and so on.
2 is corporate products ie larger switches firewalls and so on.
The switches and firewalls are OEM from different companies.
ie they are not consistant in if they have cli or not and if the cli exists it is not consistent to be the same.
Two different models can have vastly different command structures and capabilities of the command structures.
I do not know what your company does or what downtime means for the company, but I would recomend something else than D-link if you need a stable network.
Good luck
