Webcast-Catalyst9k
Normal CPU load on Sup-2T VSS 15.0
Chaps,
Just upgraded from a pair of Sup720 to Sup-2Ts and enabled VSS, firmware is 15.0.  The CPU used to average ~25%, now it's ~40%, is this normal?
JIm
1 ACCEPTED SOLUTION
VIP Super Bronze
Hi,Yes, with VSS the CPU runs
Yes, with VSS the CPU runs higher, why, I am not sure.
30 to 40% is the correct range.
VIP Super Bronze
28
