not able to access internet through 2811
on our network there is a soho router which provided by our ISP
and we have Cisco2800 series which is supposed to route us through Soho out to the internet
int fastethernet0/0 our local ip address
int fastethernet0/1 is public ip address
proper nat is configured
and
2 name servers id addresses are added
but still no luck accessing the internet
any clue
any help?
Re: not able to access internet through 2811
Can you post the config of your router?
regds
my cisco 2811 configuration is the following
Router#sh run
Building configuration...
Current configuration : 1286 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip name-server 192.168.10.244
ip name-server 62.***.***.***
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.***.*** 255.255.0.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 62.***.***.*** 255.255.255.248
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex A
dsl linerate AUTO
ip classless
ip route 0.0.0.0 0.0.0.0 62.***.***.*** permanent
ip http server
ip http authentication local
ip nat inside source list 2 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 62.240.33.0 0.0.0.7
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
scheduler allocate 20000 1000
thank you in advance
Hall of Fame Super Blue
Change
to
ip nat inside source list 2 interface FastEthernet0/1 overload
Jon
dear jon
:D
you are the best
thank you
tiny one
the internet accessing is a bit slow how to make it faster and for you knowlowdge i am connectcted to cisco2811 then to soho (isp provided router)
thank you so much
regard
NB may i get you email address please
change the configuration of:
to
as your outside interface is fe0/1 not 0/0.
Rate if it helps
thank you mr khatri
really appreciated
i was wondering why the internet access is kind of slow
may you direct me please
thank you any way
How are you measuring the performance of the internet access ?
do you have any tool being used out there to check out the same ?
did you check up the utilisation with reference to the bandwidth subscribed from your SP ?
regds
hello mr kumar
sorry being late i had to leave yesterday
it does seem to me slow in terms of 2 m adsl line and only my pc is connected to this public ip address and cisco2811 right now
no if u know about any good one i'll be very thankful
NB serving the net still a bit slow
You can verify the speed on 2 interfaces one is on your LAN (fastethernet interface) and also on your WAN (which gets u connected to the outside world)...
You can make use of some freeware tools to monitor the same..
http://www.paessler.com/prtg
Also the best possible test would be doing simultaneous downloads with only pc from multiple sites and check the performance of the link as well as the maximum usage either directly on the interface or with the tool..
regds
Sir
i 've downloaded ( PRTG Traffic Grapher 6.1.0.756 Setup (Freeware and Trial only).exe)
and i was watching the traffic on cisco2811 i've noticed that the (Traffice bandwith in )is so small (fluctuating between 10 and 20 kb/second) while (Traffice bandwith out)reaches 250 kb/second
i've tried to download softwares from different sites but still the bandwith sooo low
any hint?
waiting for your reply
thank you so much
Can you revert the bandwidth subscribed from your isp ?
Also can you change the load interval under the interfaces to 30 Seconds and check.
You can also directly log on to the router and check for the interface utilisation.
Have you tried downloading files ? whats the the total speed getting displayed during the download process ? and also is there any variations been observed to the average download speed and the speed gettig displayed once the download is completed..
regds
hello sir
i am going to reconstruct our network because we have so slow access and there are some week points we have to eliminate them so i would be very thankful if you could give me a hand
the problems are :
1- in the drwing attached to this post our
major week point is the ISA server which goes off and on many times and, this server is our main gateway for all workstations and servers in the HQ and branch offices
2- the SOHO ISP Router will be replaced with cisco 2811
now u may refer to the attached drawing and give me some suggestions(speciall about routing and default gate-way)
very appreciated your kind redirections
thank you
Simple network architecture would be pointing all the default gateway of all the servers to the respective zones configured in the firewall.
And in the firewall make sure that you have certain policies to allow connections from outside world.
Also now you have simple router/firewall concept your firewall's outside interface can be made pointing towards the lan interface of the router which will be the default gateway for the same.
And you have the router with enhanced filtering ACL's applied to allow matching to the connections permitted in the firewall.
BTW what kinda addressing being used in LAN ?
Is that belongs to public ip space or private address space ??
regds
thank you mr kumar you really in help
may be this is the final question
is my network secure with only pix 506e?? or do i need anther layer of protection
thank you again
In general you can have a PIX firewall which is more than enough on the security prespective but if you have some multihoming/policy routing or any other routing protocol requirement (which i feel is not there in ur case) you can go for a router which can take care of the same..
regds
sir
how are you doing?
i am having problem with surfcontrol web filter which is :
my web filter has been configured to block the chatting sites and it works fine for most of my users but still few of them in the head office and branch offices are able to bypass the filter and chat freely
and advice?
and if you have no idea about it
would you please tell me how to do this with pix506e
thank you
205
