Not able to add vlan (SVI) on a 6500
Hello all,
I am having an issue while trying to create a VLAN/SVI interface on my 6500 Metro Ethernet Aggregator.
I am receiving an error message that I cannot create an SVI without having the vlan added on the L2 vlan database, but the issue is that the vlan is already created there:
1. I created the vlan on the database:
CAT_6k_MT#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CAT_6k_MT(config)#vlan 1241
CAT_6k_MT(config-vlan)#name test
CAT_6k_MT(config-vlan)#exit
% Applying VLAN changes may take few minutes. Please wait...
2. Trying to add the SVI interface for that vlan
CAT_6k_MT(config)#int vlan 1241
CAT_6k_MT(config-if)#no shut
Oct 14 10:11:04.241 CST: %PM-4-SVI_ADD_CORRESPONDING_L2_VLAN: Vlan 1241 must be added to L2 database in order to be used, do <vlan 1241> from config mode.
Oct 14 10:11:04.257 CST: %LINK-3-UPDOWN: Interface Vlan1241, changed state to down
Then I checked the vlan 1241 is created on the database:
CAT_6k_MT#sh vlan id 1241
VLAN Name Status Ports
1241 VLAN1241 active Po11, Po61
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1241 enet 101241 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
Primary Secondary Type Ports
CAT_6k_MT#sh run int vlan 1241
Building configuration...
Current configuration : 41 bytes
interface Vlan1241
no ip address
end
But when I look at the interface vlan is always down/down:
CAT_6k_MT(config-if)#do sh int vlan 1241
Vlan1241 is down, line protocol is down
Hardware is EtherSVI, address is 0016.9c7b.d7c0 (bia 0016.9c7b.d7c0)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: fifo
Any ideas reagrding this?
Thanks for your help!
Alex
Re: Not able to add vlan (SVI) on a 6500
You need a switch port assigned to that vlan or that vlan allowed on a trunk.
Thanks for your reply.
That vlan is allowed on two trunks, you can see it on the show vlan command attached previously (port-channel 11 and port-channel 61) and both interfaces are up/up.
Regards!
Alex
You are using a vlan number over 1000.
Make sure you have Spanning-tree extend system-id enabled.
Contrary to what was said earlier, you dont need to assign it to a switchport to add it properly in the db.
Thanks for your response!
I checked the box and it has the command you mentioned:
Now,I tried to create a vlan using other vlan number (vlan 22 - not extended vlan) but I had the same error.
Do you know about any vlan limitation on this box? As a comment I am using VTP version 3.
Regards!
Alex
This is odd.
Can you attach a show-tech?
Sure here it is!
ok so i do see the vlan 22 to be created and active ( show vlans).
Can you try creating another vlan, example vlan 23 and see if it works?
I dont find any bug on this software, it may be a new defect.
How about disabling and re enabling the spanning-tree extend system-id and try again?
Do you have VLAN Database setup? You still need to put VLAN in VLAN Database to enable virtual interface. From enable can you go to VLAN D and see if it exists there?
Yes, the vlan exists in the vlan database (status active), here it is:
Remote SPAN VLAN
Disabled
Thanks!
Alex
The issue is that it is not being accepted as a valid L2 VLAN:
Error Message %PM-4-SVI_ADD_CORRESPONDING_L2_VLAN: Vlan [dec] must be added to L2
database in order to be used, do from config mode.
Explanation When a switch virtual interface (SVI) is created, the corresponding Layer 2 VLAN is not automatically created in the Layer 2 database.
Recommended Action Create a Layer 2 VLAN before the switch virtual interface (SVI) is created
But according to what you said, you already created the Layer 2 VLAN before adding the SVI.
Sounds like a bug or what the other gentleman said about there being a duplicate name.
Odd one.
James
Hall of Fame Super Bronze
"% Applying VLAN changes may take few minutes. Please wait.."
This is not normal.
Do you have another Vlan with the name 'test'? You can't have duplicate Vlan names, try creating the Vlan again and name it something else or just don't name it at all.
Edison
Thanks to all for your responses!
I tried to create a new VLAN and do not name it to avoid a duplicate name, but the behavior is the same. See below:
CAT_6k_MT(config)#vlan 23
CAT_6k_MT(config)#
CAT_6k_MT(config)#int vlan 23
Oct 14 15:34:57.613 CST: %PM-4-SVI_ADD_CORRESPONDING_L2_VLAN: Vlan 23 must be added to L2 database in order to be used, do from config mode.
Oct 14 15:34:57.629 CST: %LINK-3-UPDOWN: Interface Vlan23, changed state to down
CAT_6k_MT#sh vlan id 23
23 VLAN0023 active Gi1/2, Po11, Po61
23 enet 100023 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
CAT_6k_MT#sh int vlan 23
Vlan23 is down, line protocol is down
So, I can not make this SVI interface to come up and still getting that error message.
Can it be a bug?
Regards!
Alex
Could be an odd bug I guess. Did you try deleting the VLAN from the VLAN database then re-adding it?
That's all I can think of. Is there anything funny showing in the log when you get this message?
James
It sounds like you have a corrupted Vlan Database. Is this a lab or production environment? Are you running VTP transparent of server/client mode?
Edison
This a production environment. it is running VTP server mode.
I also tried to delete the vlan and recreated but it does not work either.
Here is the VTP status output:
CAT_6k_MT>en
Password:
CAT_6k_MT#sh vtp sta
CAT_6k_MT#sh vtp status
VTP Version : 3 (capable)
VTP version running : 3
VTP Domain Name : TELUM
VTP Pruning Mode : Enabled
VTP Traps Generation : Enabled
Device ID : 0016.9c7b.d7c0
Feature VLAN:
VTP Operating Mode : Primary Server
Number of existing VLANs : 682
Number of existing extended VLANs : 189
Configuration Revision : 528
Primary ID : 0016.9c7b.d7c0
Primary Description : CAT_6k_MT
MD5 digest : 0xBA 0x6F 0x2C 0xFA 0xE8 0xAD 0x76 0xCD
0x5C 0x47 0x05 0xD8 0x5D 0xD8 0x0C 0xFA
Feature MST:
Configuration Revision : 1
MD5 digest : 0x7A 0x16 0x11 0x7F 0x4B 0x1F 0x36 0x1E
0x9A 0x0D 0x19 0x80 0xC4 0x02 0xBB 0x7F
Regards!
Alex
I am guessing you also had a TAC case open on this. Can you post a resolution? I am curious to see what the issue was.
James
Here is the response from TAC, we will try this later this week, I'll let you know the result.
We really have 2 choices here. And we have to be careful because we
might lose the vlan database. It has been locked since April.
We should try to force a supervisor failover and then see if we can add
a new vlan:
Redundancy force-switchover
Then try to see if the interface vlan639 comes up after configuring it
again
Conf t
Vlan 639
Interface vlan 639
Ip address 4.4.4.4 255.255.255.0
Interface fas6/15
Switchport access vlan 639
End
Check with the command
Show ip interface brief | incl 639
If the above does not work, we need to have someone on-site in case the
cat6k erases its vlan configuration and loses its configuration
completely.
You need to have a vlan configuration from a show running output of
another switch in the VTP domain. If it has the vlans in its output,
then we can use this to recover the switch.
Also, if the vlans are erased, we need to make sure this switch does not
push that information out to the network. The correct way to do this is
to use the interface range command and shut down all of the ports. Then
reboot the switch and if it comes up with all of the vlans, to then "no
shut" the ports and allow it to communicate with the rest of the
switches in the VTP domain.
If you don't shut down all of the ports, the switch may propagate its
erased vlan configuration across the network to the other VTP switches
and erase the configuration on the entire network.
1178
