04-09-2010 04:16 AM - edited 03-06-2019 10:32 AM
Dear Friends,
There is router in my network in which SSH was working fine. due to some reason we erased all configuration. after that im not get console of router via SSH eventhogh i have configured Transparent input SSH.there is one more router in which only Transparent input SSH has configured and it is working fine. Kindly suggest.
04-09-2010 04:29 AM
If you have manually erased the router config, you need to regenerate the SSH keys for SSH to work:-
You must configure the device name & a domain name - once configured generate the SSH keys
crypto key gen rsa general-keys mod <
once generated you will be able to SSH.
HTH>
Andrew.
04-09-2010 04:33 AM
Need to regenerate your keys:
cry key gen rsa
Mod size: (we usually use 1024)
Router#sh ip ssh
SSH Enabled - version 2.0
Authentication timeout: 60 secs; Authentication retries: 3
04-09-2010 04:50 AM
Thank you all for support
