not able to connect smart card reader in WS-X4648-RJ45V-E
we have installed one Ws-4507R-E switch and it is having 4 nos of WS-X4648-RJ45V-E module. When we tried to connect one smart card reader to any of the ports in these modules it is showing not connecetd in the interface status. At the same time if we connecte the same device to 3560 switch it will work !! following atre the sh module output of 4507 switch.
sh module all
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT POE E Series WS-X4648-RJ45V-E JAE1234SPB6
2 48 10/100/1000BaseT POE E Series WS-X4648-RJ45V-E JAE1238UYDC
3 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE1236TQQY
4 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE1235TEYJ
5 48 10/100/1000BaseT POE E Series WS-X4648-RJ45V-E JAE1234SHWX
6 48 10/100/1000BaseT POE E Series WS-X4648-RJ45V-E JAE1234SPBB
M MAC addresses Hw Fw Sw Status
1 0022.90a3.b790 to 0022.90a3.b7bf 1.1 Ok
2 0022.90a3.c7b0 to 0022.90a3.c7df 1.1 Ok
3 0022.55bf.2940 to 0022.55bf.2945 1.2 12.2(44r)SG 12.2(46)SG Ok
4 0022.55bf.2946 to 0022.55bf.294b 1.2 12.2(44r)SG 12.2(46)SG Ok
5 0022.90a3.bdc0 to 0022.90a3.bdef 1.1 Ok
6 0022.90a3.c570 to 0022.90a3.c59f 1.1 Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Standby hot
Did any one face thios problem before.
When we connected the smart card reader to 3560 swithc its int status is showing 10 mbps full duplex.
Hall of Fame Super Silver
Re: not able to connect smart card reader in WS-X4648-RJ45V-E
Hello Shibi,
I would try to force the switch port to use 10 Mbps speed
int g1/1
switchport
switchport mode access
! put it in the desired vlan
switchport access vlan X
speed 10
duplex full
for example c6500 ports default to routed mode so it is a good idea to configure the switchport.
Hope to help
Giuseppe
Hello Guiseppe,
Thanks for your reply...
We alreday tried that option which you mentioned , All I would like to know is that is there any limitations to the above mentioned line card ?? Bcz when ever i try to connect this device to other switches it will work... i tried in 3560,3750 and even 6509. Everywher it is working except this module????
Hello Shibi,
here is the data sheet of your linecard
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
WS-X4648-RJ45V-E Cisco Catalyst 4500 E-Series 48-Port 802.3af PoE 10/100/1000 (RJ-45)
it is declared to be capable of 10 Mbps speed.
To see if it is a physical layer problem what happens if you put another switch in the middle like the c3560 ?
Are you able from an SVI on the 4507R to ping the card reader interface ?
We had to do in this way to connect a device with a 10/100/1000 port to an ADM system able to carry ethernet frames over SDH: directly connected there were a lot of errors on the ADM by putting an older switch in the middle everything was fine.
The problem was the timing: when running in 10 Mbps that port was actually a little too fast over the tolerances of the ADM port.
another thought:
have you tried
switchport nonegotiate on the port ?
and what if you use
no keepalive ?
Hope to help
Giuseppe
HI Giuseppe.. My problem is that when i connect this card reader port it self is not showing up....Sh interface status is showing (not connected)....I am facing this problem only while connecting to this module....if i connect this device to any other switch it will work. Also I have manually configured my laptop to 10 mbps and half duplex...and connected to this switch. That time it is working !!!! Only facing problem while connecting this device. Since this is a very critical device for our client , we need to provide a genuine reason to them that why it is not working on this module. Hope u undersatnd the situation.
Hello Shibi,
the card reader has only one NIC I suppose.
Connect it via a C3560 and then the C3560 to the new module.
Our experience with badge readers is not totally positive: some of them need to be reset and some need to have their NIC changed even if they are new and link negotiation is not their strongest feature.
You can say that the card reader NIC is probably too old to take part in negotiation with the new module ports that is technically true.
You need to provide a solution and adding or keeping a C3560 in the network can be an acceptable one.
Hope to help
Giuseppe
Purple
You might try setting the port to mdix auto . The port interface speed and duplex must be auto , you can't use mdix and hardcode speed . To me it sounds like a physical layer issue where it might need a crossover instead of a straightthru. If mdix was turned on for those other switches it might be why it worked with those. It is not on by default so unless you turned it on it is not on. There is no reason why it should not work if it works on a 3560.
Purple
Try this on the interface.
conf terminal
interface interface-id
speed auto
duplex auto
mdix auto
Enables Auto-MDIX on the interface.
Please find below the output when we connected the card reader in 3560 switch
HGH_RAD4#sh int gigabitEthernet 0/2 status
Port Name Status Vlan Duplex Speed Type
Gi0/2 Help Desk connected 3 a-full a-10 10/100/1000BaseTX
HGH_RAD4#sh run int gi
HGH_RAD4#sh run int gigabitEthernet 0/2
Building configuration...
Current configuration : 201 bytes
interface GigabitEthernet0/2
description Help Desk
switchport access vlan 3
udld port aggressive
no mdix auto
spanning-tree portfast
spanning-tree bpduguard enable
end
Following are the output when we connect the same device to 4507.
HGH_RAD#sh int gigabitEthernet 6/24 status
Gi6/24 notconnect 3 auto auto 10/100/1000-TX
HGH_RAD#sh run interface gigabitEthernet 6/24
Current configuration : 125 bytes
interface GigabitEthernet6/24
no mdix auto
end
Please note that I have connected my laptop by manually configuring its NIC to 10 mbps full/half duplex to this 4507 switch. At that time it will work. Only problem we are facing is when connecting this card reader. Since this device is a critical one in clients daily business we have no other options.
Purple
Please see above message and use that interface config on the 4507 interface and see if it comes up . You currently have no mdix auto on the interface . Change that to mdix auto and see if the port comes active. If that doesn't work you may have to open a TAC case.
Had a very similar issue, which I managed to fix, just type the
below under the interface config mode:
power inline never
WS-X4648-RJ45V-E is a PoE module which doesn't work well with legacy 10Mbps devices.
Rate it in case it fixed your issue
469
