ā09-21-2013 10:36 AM - edited ā03-07-2019 03:36 PM
hi,
I want to enable multicast sparse mode on cisco 3560 switch.I need to enabled it on L3 svi but when i go the interface mode i cant see the commands
any body can advise
is this license issue
EC-38th-IPTV-SW#sh version
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.0(1)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 22-Dec-11 00:16 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE5, RELEASE SOFTWARE (fc3)
TEC-38th-IPTV-SW uptime is 12 weeks, 4 days, 18 hours, 18 minutes
System image file is "flash:/c3560e-universalk9-mz.150-1.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560E-48PD (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FDO1212V0FC
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1F:CA:98:94:80
Motherboard assembly number : 73-10320-12
Motherboard serial number : FDO12110TGG
Model revision number : D0
Motherboard revision number : B0
Model number : WS-C3560E-48PD-SF
Daughterboard assembly number : 800-28590-01
Daughterboard serial number : FDO12110NZK
System serial number : FDO1212V0FC
Top Assembly Part Number : 800-28447-02
Top Assembly Revision Number : C0
Version ID : V01
CLEI Code Number : COM7900ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 54 WS-C3560E-48PD 15.0(1)SE2 C3560E-UNIVERSALK9-M
ā09-21-2013 12:52 PM
I have checked the Cisco Feature Navigator for this release and it says that this software with the IP Base license should support PIM Multicast routing. So it looks like it is not a licensing issue.
Have you enabled ip multicast routing?
Rick
ā09-22-2013 12:52 PM
These sort of switch model before you configure PIM under interfaces you have to enable multicast globally using below command. Pls check whether you have configured it
"ip multicast-routing distributed"
Rasika
**** Pls rate all useful responses****
