Not getting Loggs in Cisco 6500 Switch
I have configured syslog server on Core switch since then I am not able to get some logs like port up and down.
I want to set my logging parameters as it was before.
please suggest me commands for the same.
Before syslog configuration my config was as following:
#syslog
set logging server enable
set logging server 10.2.161.16
And After Syslog configuration my config is as below:
#syslog
set logging level cdp 1 default
set logging level mcast 1 default
set logging level dtp 1 default
set logging level earl 1 default
set logging level ip 1 default
set logging level pruning 1 default
set logging level snmp 1 default
set logging level spantree 1 default
set logging level sys 1 default
set logging level tac 1 default
set logging level tcp 1 default
set logging level telnet 1 default
set logging level tftp 1 default
set logging level vtp 1 default
set logging level vmps 1 default
set logging level kernel 1 default
set logging level filesys 1 default
set logging level pagp 1 default
set logging level mgmt 1 default
set logging level mls 1 default
set logging level protfilt 1 default
set logging level security 1 default
set logging level radius 1 default
set logging level udld 1 default
set logging level gvrp 1 default
set logging level cops 1 default
set logging level qos 1 default
set logging level acl 1 default
set logging level rsvp 1 default
set logging level ld 1 default
set logging level privatevlan 1 default
Please suggest commands for setting logging as it was before.
1 REPLY
Purple
Re: Not getting Loggs in Cisco 6500 Switch
   This should help .  you have everything at 1 as a default so only the most critical stuff will get posted  .   You will need to change that to a different number to get  what you are looking for.     http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/logging.html
228
