Nothing in my 2811 log
On my 2811 routers I don't get anything in the sh log. I've shutdown and reenabled interfaces and nothing appears in the log.
gateway(config-if)#do sh log
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 7 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty514(5)
    Buffer logging:  level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level informational, 90 message lines logged
Log Buffer (10000 bytes):
Any ideas, I still can't get logs to appear.
Hall of Fame Super Silver
Is it possible that you are typing some character (other than space bar or carriage return/enter key) that is interrupting the display? Many devices will display this general logging information and then wait for a continuation character (space bar or carriage return/enter key) to display the log messages. If any other key is typed then the display is terminated.
If that is not the issue then can you post the output of show run | include log
Rick
dot11 syslog
log config
logging synchronous
login
login
Thanks for the information. Can you post the output of the command show run | begin log config
Rick
r1#sh run | b log config
log config
  hidekeys
Francis,
Can you run these commands and then test again:
logging buffere debug
logging buffered 24000
Under your interface that you were testing by shutting down:
int
logging event link-status
Then do a show log and post the results.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Ok, i did and then shut the inface and bought it back up. I was able to get a log but doing that on all interfaces will it allow me to have debugging logs and etc sent to the console?
Syslog logging: enabled (0 messages dropped, 4 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 2 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Trap logging: level informational, 49 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (24000 bytes):
*Feb 17 19:45:36.051: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Feb 17 19:45:38.763: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
Your output shows that console logging is currently disabled.
If you want to send logs messages to the console then you need to enable console logging.
As you enable console logging you might want to think about severity level of messages that will be sent. If this is a lab environment then it probably does not matter and you can use logging console debugging, which will send all severity levels of log messages. If this is for a live router you might consider excluding debug level messages by doing logging console informat.
Rick
I'm still not getting any logs.
Router# sh log
    Console logging: level debugging, 261 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
    Buffer logging:  disabled, xml disabled,
                     filtering disabled
    Trap logging: level informational, 36 message lines logged
I think we need to back up a little. On your original question, you weren't getting logs to the buffer by shutting down the interface and bringing it back up. That was resolved from the post that I did yesterday:
"Ok, i did and then shut the inface and bought it back up. I was able to  get a log but doing that on all interfaces will it allow me to have  debugging logs and etc sent to the console?"
I'm lost as to what you're trying to accomplish. Are you wanting logs in memory and on the console? I'm assuming that you're consoled into the router and you're not seeing logs to the console? If that's the case add:
From one of your other posts above, you didn't have logging enabled anywhere:
dot11 syslog
log config
logging synchronous
login
login
There are 3 different types of logs: Buffered, console, monitor. In order to get those logs, you have to specify each one individually:
logging monitor debug
HTH,
John
565
