08-23-2013 07:08 AM - edited 03-07-2019 03:05 PM
I am unable to find a command similar to the "ntp access-group" command available in Nexus 7000s. What is the command for Nexus 5548s?
Thank you,
Scott
08-23-2013 07:28 AM
08-23-2013 07:32 AM
Yes, that is exactly what I'm looking for, but that command is not available on my switch:
n5k(config)# ntp ?
abort Abort the ntp configuration
authenticate Enable/Disable authentication
authentication-key NTP authentication key
commit Commit the ntp configuration
distribute Enable NTP configuration distribution
logging Enable/Disable logging of NTPD Events
peer NTP Peer address
server NTP server address
source Source of NTP packets
source-interface Source interface sending NTP packets
trusted-key NTP trusted-key
Running version: 6.0(2)N1(2a)
08-23-2013 08:39 AM
If I remember correctly, for NTP, you may have to enable "ntp distr" before you can apply other commands.
08-26-2013 06:41 AM
It turns out this is a new feature in NX-OS 6.0(2)N2(1); I upgraded to this newer code and applied the ntp access-group configuration. Thank you for your fast responses.
