Webcast-Catalyst9k
NTP ACL Nexus 5548UP
I am unable to find a command similar to the "ntp access-group" command available in Nexus 7000s.  What is the command for Nexus 5548s?
Thank you,
Scott
Everyone's tags (3)
VIP Super Bronze
Yes, that is exactly what I'm looking for, but that command is not available on my switch:
n5k(config)# ntp ?
  abort               Abort the ntp configuration
  authenticate        Enable/Disable authentication
  authentication-key  NTP authentication key
  commit              Commit the ntp configuration
  distribute          Enable NTP configuration distribution
  logging             Enable/Disable logging of NTPD Events
  peer                NTP Peer address
  server              NTP server address
  source              Source of NTP packets
  source-interface    Source interface sending NTP packets
  trusted-key         NTP trusted-key
Running version:  6.0(2)N1(2a)
VIP Super Bronze
If I remember correctly, for NTP, you may have to enable "ntp distr" before you can apply other commands.
It turns out this is a new feature in NX-OS 6.0(2)N2(1); I upgraded to this newer code and applied the ntp access-group configuration.  Thank you for your fast responses.
1030
