NTP configuration
hi all,
I made my Core router as NTP router and all other sites as clients but now what i m seeing is that some of those sites are not synchronize with ntp server. I have done also authentication with this server.all sites have same configuration but clock is showing ntp as source but not syn with it. plz tell me what can be the problem .
Second issue is that no. of giants packets are too much on my router. my router connected to switch with different connectivity means router is on fast eth and switch is on giga but both are set to auto speed and full duplex and i m also getting some rx and tx load on both devices . plz help me to rectify the problem.
thanx and regards,
Tarn
1 REPLY
Silver
Re: NTP configuration
Use the show ntp associations command output to determine if NTP is working and communicating properly.
1488
