ntp disable command doesn't work on 2960 and 3560
Hi all,
I'm configuring some 2960 and 3560 to sync to an NTP server.
I've succesfully managed to sync the switches to the NTP server but I would like the switches to use some specific ports to use for connecting to the server.
Now, according to the IOS SCG (I have 12.2 on my switches), it should be possible to diasble the NTP service at interface level using at inteface-config level:
ntp disable
I'm trying and trying but the command is simply not recognised.
Any idea?
Paolo
Everyone's tags (3)
Hall of Fame Super Gold
Re: ntp disable command doesn't work on 2960 and 3560
Command to let NTP use a particular interface is "ntp server x.x.x.x source interface ".
My understanding is that source point to the interface IP address we want to use as source-stamp for the NTP messages sent by the switch. From the manual:
For interface, specify the interface from which to pick the IP source address.
Again from the manual:
ntp disable Disable NTP packets from being received on the interface. By default, all interfaces receive NTP packets.
It seems that this command doesn't exist.
Paolo
Silver
According to the Command Lookup Tool, 'ntp disable' is only available on the following IOS trains:
12.2SR
12.2SX
12.4
12.4T
15.0S
15.1M&T
2960 and 3560 switches are running 12.2SE train.
Andras
Hi Andras,
thanks for your reply.
I've had a look at the comand lookup tool and it seems that according to it neither ntp server comand is available for those switches, while I have used that command to configur the ntp server. Maybe it's just me that doesn't understand how to sue the tool...
Both 3560 SCGs IOS Release 12.2(25)SEE and 12.2(55)SE I have mention the command.
Thanks again.
Paolo
Silver
You're absolutely right. I've submitted this information to the technical writers to correct the SCG documentations.
1151
