Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
NTP limitations C6500Sup7203B
we are planing to migrate our NTP infrastructure from a server based to a network based solution.
Therefore I'm looking for guidelines or recommendations, how many ntp clients a Cat6500Sup7203B can handle reliable (or better how many ntp requests per second).
We have about 4000 devices (server, switches and routers) that will act as NTP client.
Hendrik
1 REPLY
Purple
Re: NTP limitations C6500Sup7203B
All devices don't have to go back to a single device for ntp . If you have the common core distribution ,access model you can have the distribution boxes pull their time from the core , the access boxes can then pull their time from the distribution boxes instead of having it traverse the entire network to get its time . NTP is a very efficient protocol and doesn't require a lot of packet traffic to sync .
124
