NTP server advice
Walsby1983
Hello, i'm having issues getting various model switches to sync with a newly built NTP (Win2008) server with Atomic clock attached to it. The software for the clock is set to stratum 1. I know the clock is syncronising and the server is showing the correct time also. THe server currently has the firewall turned off so no traffic is being blocked to it.
I have the below on all switches;
clock timezone GMT 0
Clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
and
ntp server 10.0.101.15 (ip of the above server)
Currently is have a core switch (4507R) that will not sync at all;
sh clock
*23:59:53.989 GMT Wed Mar 16 2011
sh ntp as
      address         ref clock     st  when  poll reach  delay  offset    dis
~10.0.101.15      .LOCL.            1   141  1024  377     0.0  300258     8.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is 00000000.00000000 (00:00:00.000 GMT Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
I also have multiple access switches (3550's, 3750's,3548's) that must have synced at some point as they were originally showing a 1993 date but are now up to date but not sync'd properly;
sh clock
.12:28:06.346 GMT Mon Feb 27 2012
sh ntp as
      address         ref clock     st  when  poll reach  delay  offset    disp
~10.0.101.15      .LOCL.            1   326  1024  377     9.7  121575   352.5
sh ntp status
nominal freq is 381.4697 Hz, actual freq is 381.4697 Hz, precision is 2**17
reference time is D2ECEEC7.7AB25EFE (16:09:43.479 GMT Mon Feb 20 2012)
clock offset is -782401.5959 msec, root delay is 1.37 msec
root dispersion is 782590.12 msec, peer dispersion is 188.52 msec
Is there a way to force synchronisation or is a reboot of the device needed for them to sync?
Thanks in advance, any advice appreicated.
18 Replies 18
Thanks Kunal, if i add that to the config I get
sh ntp status;
Clock is synchronized, stratum 3, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**7
reference time is D2F72BBF.EE855780 (10:32:31.931 GMT Tue Feb 28 2012)
root dispersion is 7.81 msec, peer dispersion is 7.81 msec
sh ntp as;
*~127.127.7.1      127.127.7.1       2    13    64  377     0.0    0.00     7.8
~10.0.101.15      .LOCL.            1    92  1024  377     0.0  691245   944.1
Isnt this setting it as a master for other devices even though not synced with the actual NTP server?
please configure below command in master cisco switch and please share ntp configuration for core switch (4507R)
ntp update-calendar
ntp update-calendar
end
Below is the debug info from the Timesync software;
Timesync NTP Service 3.2
Windows Info
Version=6.1 Build 7601 0601
Winsock Info
Version=1.1
HighVersion=2.2
Description=WinSock 2.0
Status=Running
MaxSockets=32767
MaxUDP=65467
Timezone Info
Bias=0
Standard Name=GMT Standard Time
Standard Bias=0
Standard date=0/10/5  2:0:0:0
Daylight Name=GMT Daylight Time
Daylight Bias=-60
Daylight date=0/3/5  1:0:0:0
The server has UTC 0 timezone - would this affect it as I have GMT in the switch configs...
Alan
You are quite correct that if you configure any Cisco device with the ntp master command then you have instructed that device that it should consider itself authoritative for NTP and it will offer NTP time to anything that asks. But it still has only its own (somewhat undependable) clock as the source for time. I urge you to not do this and to find what is preventing the Cisco from sync with the server that has the atomic clock.
Is this the timesync from ravib? I have looked at what they say on their website and it looks like it is requesting time from the atomic clock at Boulder. That would be good for setting the time in the PC. But it does not look like it runs an implementation of NTP that would support the PC acting as an authoritative NTP server. If the server is learning good NTP time but is running the regular Windows time service for sharing time with other devices then this would explain why your Cisco switches are not getting sync with the server.
Rick
Rick
