ntp server for switches
Dear ,
I have 2950,2960.I want to create ntp server for swithces.can i use any computer(winxp,2000,2003)for ntp server.
Re: ntp server for switches
You can setup your router to be a NTP server.
yes you can.
dear,
I want to use any computer (winxp,2000,2003)instead of router.can i do.
Yes, you can configure a Windows server or workstation to act as a NTP server. It involves editing the registry and setting HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Parameters\LocalNTP to 1.
The following Microsoft documents describe how to configure different flavours of Windows as NTP servers:
Windows 2000: http://support.microsoft.com/kb/216734
Windows XP: http://support.microsoft.com/kb/314054
Windows 2003: http://support.microsoft.com/kb/816042
Whatever device you decide to use as your NTP server, make sure that it is reliable and highly available.
181
