05-26-2012 02:32 PM - edited 03-07-2019 06:55 AM
hi,
i am setting a C1841 to sync its time with another C1841 over net. here is my setting with dont work !
SERVER:
clock set 23:01:00 26 MAY 2012
ntp master 5
ntp source f0/1
ntp access-group serve-only 10
access-list 10 permit 10.10.2.2
CLIENT:
ntp server 10.10.1.1 source loopback 0
ntp update-calendar
*** both routers can ping eachother's ip address 100/100. tried both loopback and physical addresses.
here is out put of show ntp stat on the CLIENT:
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 250.0182 Hz, precision is 2**24
reference time is 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
loopfilter state is 'FSET' (Drift set from file), drift is -0.000073081 s/s
system poll interval is 64, never updated.
PS: its not an ASR9K since seems like no body knows abt it lol
THNX,
Soroush.
05-26-2012 03:44 PM
Is 10.10.1.1 the fa0/1 address on the server? Is 10.10.2.2 the loop back address on the client?
05-26-2012 03:51 PM
Yes.
10.10.1.1 F0/1 Server
10.10.2.2 Lo0 Client
05-26-2012 06:32 PM
Let's keep it nice and simple first. Get rid of this line temporarily.
ntp master 5
Get rid of this. Cisco don't recommend using this command
05-26-2012 11:09 PM
I did that without the access-list no luck, did do it with the master 5 thou, but its a requirement to do Stratum 5!
i'll try it after the weekend thou.
thx Leo.
05-28-2012 03:16 PM
Can you post the output to the command "sh ntp a"?
How is your NTP time synchronize?
