Webcast-Catalyst9k
nvram_erase command in rommon privilege mode doesn't work.
I am running native IOS version 12.2(17d)SXB11a on my lab CAt6506 with SUP720/MSFC3.
I tried to follow this article
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml
and issue the following commands
rommon 1>priv
rommon 2>nvram_erase
It says nvram_erase command not found.
Can someone offer any suggestion?
Purple
Re: nvram_erase command in rommon privilege mode doesn't work.
What is it you are trying to accomplish ? If you are trying to erase a config it may not let you because you are in rommon mode , you have very limited commands available because the switch is not booted up .
Are u performing the Crt+Break in the MSFC boot or in the Supervisor boot?
"Note: Supervisor Engine 720 has the nvram_erase command in Route Processor (MSFC) ROMmon, and it is not a valid command in Switch Processor (Supervisor Engine) ROMmon."
U have a Supervisor 720, right ?
So let the Sup boot be performed, and as soon as u see the MSFC letters perform the Crt+Break, and do it like document tells.
Petr?nio
414
