NX2000 port connectivity
Rosa Ladeira
I have nx2000 boxes connected to nx7000 fiber module.
There is a intermittent error occuring on nx7000 fiber module.
7000 fiber module drops down and all NX2000 boxes lose connectivity.
When 7000 fiber module comes up, some equipment, not all, can not be reached through console port via network.
These equipment are datacenter air conditioner console port, storage controller console port (iscsi controller interfaces run fine).
It seems that handshake between these equipments and NX2000 ports are not fine.
Any idea ?
Thanks, Rosa
7 Replies 7
Amit Singh
Hi Rosa,
Do you have any errors in the logs or console? Could you please pate that.
What is the NX-OS version you are running on the Nexus7000? What are the Nexus 2K types?
Cheers,
-amit singh
Logs
Unfortunately, when 7000 fiber module drops down internal backbone drpos down too. No messages on servers.
Immediately after connectivity comes up storage controler signs it is up. No errors.
Version
nx7000-wc0# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 3.22.0
  kickstart: version 5.1(1)
  system:    version 5.1(1)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart-npe.5.1.1.bin
  kickstart compile time:  12/25/2020 12:00:00 [10/24/2010 08:25:25]
  system image file is:    bootflash:///n7000-s1-dk9-npe.5.1.1.bin
  system compile time:     9/2/2010 19:00:00 [10/24/2010 09:34:48]
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 4109596 kB of memory.
  Processor Board ID JAF1444BLKS
  Device name: nx7000-wc0
  bootflash:    2029608 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 20 day(s), 6 hour(s), 35 minute(s), 18 second(s)
Last reset at 254133 usecs after  Sat Nov  5 09:47:59 2011
  Reason: Reset Requested by CLI command reload
  System version: 5.1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
  CMP BIOS version:        02.01.05
  CMP Image version:       5.1(1) [build 5.0(0.66)]
  CMP BIOS compile time:   8/ 4/2008 19:39:40
  CMP Image compile time:  9/2/2010 19:00:00
nx7000-wc0#
Rosa, can you, please, attach:
"show logging log", "sh mod", "sh interface ethernet x/y transceiver details" from interfaces to which fex are connected
nx7000-wc0# sh mod
Mod  Ports  Module-Type                      Model              Status
1    32     10 Gbps Ethernet Module          N7K-M132XP-12      ok
5    0      Supervisor module-1X             N7K-SUP1           active *
10   48     10/100/1000 Mbps Ethernet Module N7K-M148GT-11      ok
Mod  Sw              Hw
1    5.1(1)          2.0
5    5.1(1)          1.8
10   5.1(1)          1.6
Mod  MAC-Address(es)                         Serial-Num
1    c4-71-fe-a5-bb-1c to c4-71-fe-a5-bb-40  JAF1445AGRQ
5    b4-14-89-e3-6f-00 to b4-14-89-e3-6f-08  JAF1444BLKS
10   c4-71-fe-1b-d1-f4 to c4-71-fe-1b-d2-28  JAF1444CGPG
Mod  Online Diag Status
1    Pass
5    Pass
10   Pass
Xbar Ports  Module-Type                      Model              Status
1    0      Fabric Module 1                  N7K-C7010-FAB-1    ok
2    0      Fabric Module 1                  N7K-C7010-FAB-1    ok
3    0      Fabric Module 1                  N7K-C7010-FAB-1    ok
Xbar Sw              Hw
1    NA              1.1
2    NA              1.1
3    NA              1.1
Xbar MAC-Address(es)                         Serial-Num
1    NA                                      JAF1443BRQR
2    NA                                      JAF1443BSGN
3    NA                                      JAF1443BMPE
* this terminal session
nx7000-wc0#
nx7000-wc0# sh interface Ethernet1/10 transceiver details
Ethernet1/10
    transceiver is present
    type is 10Gbase-SR
    name is CISCO-SUMITOMO
    part number is SPP5100SR-C1
    revision is A
    serial number is SPC144604SH
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 50/125um OM3 fiber is 300 m
    Link length supported for 62.5/125um fiber is 26 m
    cisco id is --
    cisco extended id number is 4
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   26.74 C        75.00 C     -5.00 C     70.00 C        0.00 C
  Voltage        3.32 V         3.63 V      2.97 V      3.46 V        3.13 V
  Current        5.30 mA       10.50 mA     2.00 mA     9.00 mA       2.50 mA
  Tx Power       -2.65 dBm       1.69 dBm  -11.30 dBm   -1.30 dBm     -7.30 dBm
  Rx Power       -5.00 dBm       1.99 dBm  -13.97 dBm   -1.00 dBm     -9.91 dBm
  Transmit Fault Count = 1
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
nx7000-wc0#
Ethernet111/1/1 -> storage controller console port
2011 Nov 23 11:01:45 -> intermittent error occuring on nx7000 fiber module (storage administrative port looses its IP)
2011 Nov 23 11:04:49  -> fiber module comming on
2011 Nov 25 10:46:40 -> Forcing storage IP via external host as console on storage port
nx7000-wc0# sh logging log | grep "Nov 2" | grep "Interface Ethernet111/1/1"
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/1 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/10 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/13 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/16 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/17 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/18 is down (module removed)
2011 Nov 23 11:01:45 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/19 is down (module removed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/11 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/12 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/14 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/15 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/1 is down (Interface remove
d)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/10 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/13 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/16 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/17 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/18 is down (Interface remov
ed)
2011 Nov 23 11:01:46 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/19 is down (Interface removed)
--------------------> fiber module comming on
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/13, operational speed changed to 100 Mbps
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/13, operational duplex mode changed to Full
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/13, operational Receive Flow Contr
ol state changed to off
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/13, operational Transmit Flow Cont
rol state changed to on
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/13 is up in mode access
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/16, operational speed changed to 100 Mbps
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/16, operational duplex mode changed to Full
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/16, operational Receive Flow Contr
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/16, operational Transmit Flow Cont
2011 Nov 23 11:04:49 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/16 is up in mode access
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/10, operational speed changed to 1 Gbps
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/10, operational duplex mode changed to Full
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/10, operational Receive Flow Contr
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/10, operational Transmit Flow Cont
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/10 is up in mode access
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/18, operational speed changed to 1 Gbps
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/18, operational duplex mode changed to Full
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/18, operational Receive Flow Contr
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/18, operational Transmit Flow Cont
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/18 is up in mode access
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/19, operational speed changed to 1 Gbps
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/19, operational duplex mode changed to Full
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/19, operational Receive Flow Contr
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/19, operational Transmit Flow Cont
2011 Nov 23 11:04:50 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/19 is up in mode access
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/10 is down (module removed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/13 is down (module removed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/16 is down (module removed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/18 is down (module removed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet111/1/19 is down (module removed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/1 is down (Interface remove
d)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/11 is down (Interface remov
ed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/12 is down (Interface remov
ed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/14 is down (Interface remov
ed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/15 is down (Interface remov
ed)
2011 Nov 23 11:05:26 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/17 is down (Interface remov
ed)
2011 Nov 23 11:05:27 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/10 is down (Interface remov
ed)
2011 Nov 23 11:05:27 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/13 is down (Interface remov
ed)
2011 Nov 23 11:05:27 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/16 is down (Interface remov
ed)
2011 Nov 23 11:05:27 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/18 is down (Interface remov
ed)
2011 Nov 23 11:05:27 nx7000-wc0 %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet111/1/19 is down (Interface remov
ed)
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/13, operational speed changed to 100 Mbps
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/13, operational duplex mode changed to Full
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/13, operational Receive Flow Contr
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/13, operational Transmit Flow Cont
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/13 is up in mode access
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/16, operational speed changed to 100 Mbps
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/16, operational duplex mode changed to Full
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/16, operational Receive Flow Contr
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/16, operational Transmit Flow Cont
2011 Nov 23 11:08:24 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/16 is up in mode access
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/10, operational speed changed to 1 Gbps
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/10, operational duplex mode changed to Full
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/10, operational Receive Flow Contr
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/10, operational Transmit Flow Cont
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/10 is up in mode access
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/18, operational speed changed to 1 Gbps
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/18, operational duplex mode changed to Full
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/18, operational Receive Flow Contr
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/18, operational Transmit Flow Cont
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/19, operational speed changed to 1 Gbps
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/19, operational duplex mode changed to Full
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/19, operational Receive Flow Contr
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/19, operational Transmit Flow Cont
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/18 is up in mode access
2011 Nov 23 11:08:25 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/19 is up in mode access
2011 Nov 25 10:46:35 nx7000-wc0 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet111/1/17 is down (Administratively down)
2011 Nov 25 10:46:40 nx7000-wc0 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet111/1/17 is admin up .
2011 Nov 25 14:26:06 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/1, operational speed changed to 100 Mbps
2011 Nov 25 14:26:06 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/1, operational duplex mode changed to Full
2011 Nov 25 14:26:06 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/1, operational Receive Flow Contro
2011 Nov 25 14:26:06 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/1, operational Transmit Flow Contr
2011 Nov 25 14:26:06 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/1 is up in mode access
2011 Nov 25 14:26:23 nx7000-wc0 %ETHPORT-5-SPEED: Interface Ethernet111/1/17, operational speed changed to 100 Mbps
2011 Nov 25 14:26:23 nx7000-wc0 %ETHPORT-5-IF_DUPLEX: Interface Ethernet111/1/17, operational duplex mode changed to Full
2011 Nov 25 14:26:23 nx7000-wc0 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet111/1/17, operational Receive Flow Contr
2011 Nov 25 14:26:23 nx7000-wc0 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet111/1/17, operational Transmit Flow Cont
2011 Nov 25 14:26:23 nx7000-wc0 %ETHPORT-5-IF_UP: Interface Ethernet111/1/17 is up in mode access
nx7000-wc0#
air conditioner was attached after nx7000 fiber module crashes.
