Community Member
NX5020 - N5K-M1404 4x1/2/4G FC Module
I have a NX5020 configured and working fine.
  BIOS:      version 1.2.0
  loader:    version N/A
  kickstart: version 4.0(1a)N2(1)
  system:    version 4.0(1a)N2(1)
  BIOS compile time:       06/19/08
  kickstart image file is: bootflash:/n5000-uk9-kickstart.4.0.1a.N2.1.bin
  kickstart compile time:  2/25/2009 0:00:00 [02/25/2009 05:29:12]
  system image file is:    bootflash:/n5000-uk9.4.0.1a.N2.1.bin
  system compile time:     2/25/2009 0:00:00 [02/25/2009 05:56:57]
nx5020-wc0# sh module
Mod Ports  Module-Type                      Model                  Status
1    40     40x10GE/Supervisor               N5K-C5020P-BF          active *
2    8      4x10GE + 4x1/2/4G FC Module      N5K-M1404              ok
3    6      6x10GE Ethernet Module           N5K-M1600              ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    4.0(1a)N2(1)    1.2     --
2    4.0(1a)N2(1)    1.0     20:41:00:0d:ec:e1:98:40 to 20:44:00:0d:ec:e1:98:40
3    4.0(1a)N2(1)    1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    000d.ece1.9848 to 000d.ece1.986f         JAF1339BCAA
2    000d.ece1.9870 to 000d.ece1.9877         JAF1338ABNG
3    000d.ece1.9878 to 000d.ece1.987f         JAF1335ASJN
I am wondering about using 1G port of N5K-M1404 module but can not see them:
interface Ethernet1/40
  description UpLink Switch VISGRAF - Sala 128
  switchport access vlan 6
  no shutdown
interface Ethernet2/1
  switchport mode trunk
  no shutdown
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet2/4
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Ethernet3/4
interface Ethernet3/5
interface Ethernet3/6
What should I configure in order to have them enabled ?
Everyone's tags (1)
VIP Super Bronze
Hi Rosa,on the Nexus series,
Hi Rosa,
on the Nexus series, it does not tell you weather the port is 1Gig or 10Gig.  It depends on the optic you use. SFP+ is 10Gig SFP is 1Gig.
Community Member
Reza tks.Are you telling I
Reza tks.
Are you telling I can use a 1Gig SFP (booth sides) on port eth 2/1 even it is a 10GE ?
Community Member
As I have showed, using
As I have showed, using :
NX5020,  4x10GE + 4x1/2/4G FC Module  (N5K-M1404), interface Ethernet2/1 and a SFP (1G)
Cat 2960-S SFP (1G)
do not work
