01-04-2010 04:50 PM - edited 03-06-2019 09:08 AM
Hello everybody
I was using the Cisco Tools Configuration to a Nexus 5010, but in the Software License Options mention 2 License, I have a question about that:
In the ordering information I understand that the N5010-SSK9 is to rich features of the table 4 : http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/product_bulletin_c25-551648_ps9670_Products_Bulletin.html
Thanks a lot,
01-04-2010 04:57 PM
Hi Rene,
As I understand, the N5010-SSK9 license is only required if you need the following features:
From the following link, any feature not included in the Storage Services license package is bundled with the Cisco NX-OS software and is provided with the switch hardware at no additional charge.
Cheers,
Conor
01-04-2010 05:37 PM
Thanks Cheers,
I made a mistake, I was referring to the license N5000FMS1K9 (Nexus 5000 Fabric Manager Server License), do you have idea when is required that license?
01-04-2010 05:56 PM
Hi Rene,
It should be the Fabric Manager Server license and allows access to certain Cisco Fabric Manager features. It's required for features such as historical performance monitoring, Cisco Fabric Manager java client login to a remote server, report generation and viewing with the Web Client.
I've found the following document on the Nexus 5000 Fabric Manager Server which might give you a bit more information.
You can run the unlicensed version of Fabric Manager.
Cheers,
Conor
01-05-2010 06:58 AM
I can look in the link
Note
The unlicensed Cisco Fabric Manager can only monitor and configure one fabric at a time. You must use the Open menu to switch to a new fabric, which causes the application to stop monitoring the previous one and to rediscover the new fabric.
I only have a NX5K i don´t have MDS, so that I thinks that unlicensed Cisco Fabric Manager is sufficient.
Thanks again,
