06-04-2008 08:59 AM - edited 03-05-2019 11:25 PM
In which slot should I insert WAN module in Cat 6509-E? I could not find any relevant document on it.
cheers~
fawad
06-04-2008 09:23 AM
Fawad, can you let me know the part number you are referring to so that it becomes easier to understand.
-> sushil
06-04-2008 09:48 AM
Fawad,
For OC-12, you need the SIP-400 module
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9e6.html
It's just like a line card, it can be inserted anywhere in the chassis except on slot 5 and 6 (Supervisor Slots).
Once you have the SIP-400, then you need the SPA,
http://www.cisco.com/en/US/prod/collateral/modules/ps6267/product_data_sheet0900aecd8027cba7.html
HTH,
__
Edison.
Please rate helpful posts
06-04-2008 11:29 AM
hi Edison,
Thanks for your response. I have inserted the SIP-400 and the SPA in slot 4. Below is the output of "sh module". SPA is in slot 0. The lights are green. I think it is fine..
What do you think?
Mod Ports Card Type Model Serial No.
2 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAD04270HWG
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL114245CC
4 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAE12078L26
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL11456EFD
8 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL09337H8U
Mod MAC addresses Hw Fw Sw Sta------------ -------
2 00d0.d3a5.a7d1 to 00d0.d3a5.a7d8 1.3 5.4(2) 8.5(0.46)RFW Ok
3 001d.a2f0.b410 to 001d.a2f0.b43f 2.6 12.2(14r)S5 12.2(18)SXF1 Ok
4 001e.f717.a380 to 001e.f717.a3ff 2.5 12.2(18)SXF1 12.2(18)SXF1 Ok
5 001a.2f3c.7924 to 001a.2f3c.7927 5.4 8.4(2) 12.2(18)SXF1 Ok
8 0014.f2f9.963c to 0014.f2f9.966b 2.3 12.2(14r)S5 12.2(18)SXF1 Ok
Mod Sub-Module Model Serial Hw Status
3 Distributed Forwarding Card WS-F6700-DFC3B SAL11477AUB 4.6 Ok
4.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL1145686H 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL11456EV4 3.0 Ok
8 Centralized Forwarding Card WS-F6700-CFC SAL09316GT9 2.0 Ok
Mod Online Diag Status
2 Pass
3 Pass
4 Pass
4/0 Not Applicable
5 Pass
8 Pass
06-04-2008 11:45 AM
Yup, it looks good.
