Community Member
OID CardIndex Number Changes on WS-C650X
I've got a WS-C6504-E running following hardware:
1     SUP720-3B
2     WS-X6148A-GE-TX
3     WS-X6516A-GBIC
4     EMPTY
IOS Tested:
s72033-advipservicesk9_wan_mz.122-18.SXF6.bin
s72033-adventerprise_wan-mz.122-33.SXI4a.bin
I boot up the 650X with the following hardware installed:
1     SUP720-3B
2     WS-X6148A-GE-TX
and after boot up i check following OID via GET-IF Tool:     .1.3.6.1.4.1.9.3.6.11.1.3     (cardDescr)
I get following output:
enterprises.9.3.6.11.1.3.5     :     Supervisor Engine 720
enterprises.9.3.6.11.1.3.6     :     Policy Feature Card 3
enterprises.9.3.6.11.1.3.7     :     MSFC3 Daughterboard
enterprises.9.3.6.11.1.3.8     :     48-port 10/100/1000 RJ45 EtherModule
After inserting the WS-X6516A-GBIC in Module 3 it looks as following:
enterprises.9.3.6.11.1.3.8     :     48-port 10/100/1000 RJ45 EtherModule     IS STILL THE SAME
enterprises.9.3.6.11.1.3.9     :     SFM-capable 16 port 1000mb GBIC           new inserted
Now i reload the WS-C6504 with the WS-X6148A-GE-TX within Module 3
After the Reload the Index look as following:
enterprises.9.3.6.11.1.3.9     :     48-port 10/100/1000 RJ45 EtherModule     AFTER RELOAD IT CHANGED FROM .8 to .9 !!!
enterprises.9.3.6.11.1.3.10     :     SFM-capable 16 port 1000mb GBIC       IS NOW .10 instead of previous .9 !!
Now why does the WS-X6148A-GE-TX change its index from .8 to .9 if the WS-X6516A-GBIC is inserted?
Is there anyway of resetting this value from .9 back to .8 via CLi after boot up ?
Thank you.
Everyone's tags (4)
242
